  4. Limewire crap
Limewire crap
19 Posts 10 Posters 2.2k Views
    No, nothing works. They block it out pretty good. i29 blocks all p2p. But its all good i just use Morpheus. Network is different than limewire, and im accualy starting to like it more then limewire. It has alot more options. *damn banners tho:icon_puke_l:
      do they block bit torent? If not, look into that.
        www.torrentspy.com
        use azureus also.....
          is that a file sharing program?
          Whats with the website. Never heard of either
            I've had great luck using the client from www.utorrent.com (very small program, uses very little system resources) I can't speak for Azurues.
            I get my seeds from a number of torrent sites, including what brian listed above. If you use utorrent you can search various different torrent sites by choosing them from a drop down list on the upper right hand corner.
              http://computer.howstuffworks.com/bittorrent.htm
              • BlueSRT0483B Offline
                BlueSRT0483
                You can download Azereus; and than search for torrents online on the web at numerous sites, if 1 doesn't have what your looking for try another...
                ex:'s would be.. www.torrentreactor.net, www.isohunt.com thepiratebay.org
                or you can google torrent search and it'll show a few others as well.
                usually good for larger files... prolly not as quick to download 1 certain song or something like morpheus or limewire... usually you'll find numerous songs all zipped up, etc.
                2004 Dodge SRT-4
                ...Formerly "A853"...
                • In2LudeI Offline
                  In2LudeI Offline
                  In2Lude
                  well my limewire had the same problem, but i use Cable internet. Try to go to File then Click on Connect. If that don work, then restart limewire and do the same thing. If that don't work. Then i wouldn't know ur problem. Bitcomet i think is better. Limewire has a lot of fake stuff. That's my opinion.
                    uhhh...i think i might have tried that..
                    • In2LudeI Offline
                      In2LudeI Offline
                      In2Lude
                      I wouldn't know then, sry bro
                        BlueSRT0483
                        Is this on a laptop by any chance? Because what I would reccomend is to try to get on a different network (Isp) and see if the same thing is happening on like any other internet; if it still doesn't work if you went that route, it could just be that it maybe a setting on your computer. I had cable, and Limewire seemed to work fine, with the only crappy part is somethings aren't real, and when you dbl-click to d/l, it will take you to a site... For ex: (Sponsored Result) <-- If I remember that correctly; would be something not worth clicking, since it wouldn't be a download. I know if you read into the technical support of Azereus, you can mess with the port settings to get a better connection, and access more people to download from. Some Isp's tend to block certain ports.. Are you also working thru a router? Just curious..
                        2004 Dodge SRT-4
