  4. Dyno Queen
Dyno Queen
54 Posts 19 Posters 3.0k Views
  • capitljC Offline
    capitljC Offline
    capitlj
    I need more specs on that motor I'm planning a twin setup for the 5.0 on my cat.
    > Mitch Hedberg wrote:
    2004 Impala LS 3.8
      I know that aint a 5.0L
      • XJHEADX Offline
        XJHEADX Offline
        91nbtsi wrote:
        Especially when you have a garden hose for a supply line:icon_cyclops:
        Anyone have an extra washer for 5/8" garden hose, I forgot to put one in:icon_thumleft:
        Actually is was a cracked fitting, -10 AN to 1/2 pipe thread at one of the rails. Andy at DYNOTUNE found one for me this morning in Watertown and put it on. Hopefully some numbers this week..
          thrash
          97jeep wrote:
          on E-85 gas, thats interesting,
          or did i miss understand you
          Anyone with standalone or at least programmable fuel and forced induction should give E-85 a shot. It works out to about 104 octane, but costs about as much as regular.
          Additionally, E-85 burns cooler and seems to have some other non-octane related detonation resistance.
          Boosted cars do especially well on E-85.. you can run significant additional boost and additional spark advance.
          Note - this is just what I've read. I've got no direct E-85 experience. But given that we are ND/MN residents, where E-85 is most prevalent.. everyone here with forced induction and good fuel control should give it a shot.
          Other notes - unless you've got at least 30% headroom in your injectors, you'll need bigger ones, as E85 requires more fuel per combustion event (10:1 AFR instead of 14:1 for normal gas)
          If you learned nothing from this - remember the key take away - E85 is government subsidized 104 octane race gas you can get anywhere in the midwest. 🙂
          • capitljC Offline
            capitljC Offline
            capitlj
            in my cat of course it is, xjhead's probibly isnt but that doesnt matter im interes in cam lift, duration, overlap, combustion chamber, head flow rate, rocker ratios, and of course HORSEPOWER.
            2004 Impala LS 3.8
            • XJHEADX Offline
              XJHEADX Offline
              I'm interested in; cam lift, duration, overlap, combustion chamber, head flow rate, rocker ratios, and of course HORSEPOWER.
              Lift mid .600's N/A was .714
              dur around 230 268
              lobe sep. 116* 108
              Heads are TFS-R twisted wedge
              Intake flow [email protected]??
              1.7 rockers
              HORSEPOWER TBD
              • ruthless351R Offline
                ruthless351
                Congrats on the ride xj. Cant wait to see it around town. Where did you get your turbo kit? O and just to let everyone know.........i have a 5.0.......no poser here and no cocky son of a @#$%! either. I have to say.......Damn josh i think you pissed them off.
                • XJHEADX Offline
                  XJHEADX Offline
                  Well I guess this wastegates are too small, Andy had some big time boost creep with it tonight.. Shot up to 17 psi at 5500 rpm pretty quick with 9 lb. springs in it. I guess sunday is out
                    Deltagates for ya! @ least you dont have their BOV too, cuz it only holds about 10psi.
                      Overnight some Tial 38mm's.
                      • XJHEADX Offline
                        XJHEADX Offline
                        But, whatever it is..... throw it as far as you can, bury it then pour concrete over it. Too many people have popped motors because of Deltagates...... stick with Tial.
                        jon3k07-02-2003, 03:42 PM
                        Deltagate = pure crap
                        Theres a reason its cheaper than other wastegates ... you get what you pay for. Tial is what most people run, I'd never trust my motor to a deltagate, ugh.
                        egg07-02-2003, 04:00 PM
                        i agree, notice that ebay has millions of these for sale. deltagates are known for boost creep.
                        Victorious07-02-2003, 04:12 PM
                        Yeah John, the turbos on det's have internal wastegates, and the deltagate is an external wastegate.
                        As noted before, deltagates are prone to boost creep. And they need to be taken apart and cleaned like every three months.
                        I suggest you just run a TIAL 35 or 38mm. The protech manifold is flanged to fit either wastegate.
                        and while we are at it we need to get rid of that turbo and hook you up with a more effecient one.
                        unlucky07-02-2003, 05:13 PM
                        I popped a motor with a deltagate. 9psi spring.. spiked about 17psi on me at a 130mph blast down the freeway. 😞
                        Turbo91SER07-02-2003, 07:23 PM
                        See Travis, that's what you get for doing 130 down the freeway! J/K.........:D 🆒 😄 🆒
                        I know of 3 people personally that have lost engines to Deltagates.............. Travis, Quickzeek and JBanach77
                        Roll the dice if you like...... it's only a matter of time
                        unlucky07-02-2003, 07:57 PM
                        Well.. SOMEONE had to beat up on that Cobra... 😉
                        Yellow4g6307-03-2003, 03:53 AM
                        I 2nd that Delta crapers blow. I was tryin to tune a GSR on the dyno one day and it was suppose to be a 6psi srping.... nope call it more like 9psi spike. Lucky he had all the supporting mods and a PFC.
                        Killdannow02-22-2006, 06:15 PM
                        Bump.
                        Anyone got deals on a tial?
                        choaderboy202-22-2006, 06:40 PM
                        Deltagate MK II P/N 10101
                        Is this the standard wastegate that usually comes with some dets?
                        Would it be suitable for a t3/t04b w/ protech mani setup?
                        Deltagate=crap. Get the new Turbonetics progate, works really well.
                        chriscar02-22-2006, 07:27 PM
                        Nice bump of a 2.5 year old thread.
                        C
                          I have a couple 38mm Tial's laying here if you need.
                          • XJHEADX Offline
                            XJHEADX Offline
                            Thanx Dave, think I can pick them up in the AM????
                            • ZeroZ Offline
                              ZeroZ Offline
                              Zero
                              yeah, e85 is nice, I heard a story of an evo guy with a large turbo deleting the intercooler and with just e85 fuel and 217+ degree intake temps he saw no knock. I think you'll be ok. But e85 requires anodization of aluminum or steel parts because it corrodes Al.
                              Chocolate Rain ;)
                              MPI conquest
                              • DanglerD Offline
                                DanglerD Offline
                                Dangler
                                my buddy's low 11 second s/c mustang would not run on e85, no matter how he tuned it. tried for 3 or 4 months w/ no luck, and this guy is as smart w/ a motor\puter\tuning as anyone i've met.... not sure the reason it didn't work, but it didn't
                                  Just needed a trip to Andy. 🙂
                                  Andy has e85 down to a science.
                                  • capitljC Offline
                                    capitljC Offline
                                    capitlj
                                    Sweet man thanks I know both me and shawn want to run boosted motors and i just want to get as much research done as possible.
                                    2004 Impala LS 3.8
                                    • N Offline
                                      N Offline
                                      Ngige
                                      turbomustangs.com is your best friend
                                      Francis Njau
                                      2004 Subaru STI (Stock)
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        Anybody want to buy some slightly used T60-1's??:rolleyes:
                                          you upgradeing already?
