  4. No more 93 oct in Fargo??
17 Posts 11 Posters 743 Views
  • raviR Offline
    raviR Offline
    ravi
    The BP station I usually fill up at (Main ave. in west fargo) no longer carries 93. I went to fill up there a while back, and they changed to 92 oct.
    This was the only station I knew of in the FM area with 93. Are there any other places to pick up 93 or even 94 at the pump? Thanks guys.
    2008 Audi A4
    2000 Audi S4
    - Sold
    12.4@116
      not that i am aware of.
        I would recommend Brady's in Moorhead for their premium. I don't believe its as high of octane, but it is non-oxygenated, and supposedly thats supposed to be a better "performance" gas...
        • Afsil80A Offline
          Afsil80A Offline
          Afsil80
          Ravi:
          Were you in Grand Forks on Tuesday?
          -Peter
          1991 240SX
          • ticklemedalyT Offline
            ticklemedaly
            unless you are extremely high performance to where you really need the high octane, any 91+oct will do around here. The best gasoline doesn't exist up in this area yet, and that is the "Top Tier Detergent Fuels" which are currently only offered in major metro areas. It will eventually make its way up here, but you will be ok with 91 or 92. I usually go to Jimmy's BP right off of 45th and interstate. They have 92 and is reasonably priced with others. You will not notice any difference between a 91 and 92 oct unless you are extremely high performanced.
            XBL G-tag: TickleMeDaly83
              AFSil80 wrote:
              Ravi:
              Yeah i think i saw you on saunday when i was up there. but for 93 idk
                the bp in north north moorhead is suppost to be non oxygenated as well. and has 92.
                • karter_2_22K Offline
                  karter_2_22
                  i saw him aswell at qudobas on sunday
                    Ravi, is your car tuned for 93? I assume thats why you atre wondering...
                    • BlueSRT0483B Offline
                      BlueSRT0483
                      I was told, or heard..
                      That the Octane Rating is the minimum of what the gas is, so for ex: if it's a minimum of 92, the actual octane reading could be 93, or 94, etc.
                      2004 Dodge SRT-4
                      ...Formerly "A853"...
                      • raviR Offline
                        raviR Offline
                        ravi
                        Actually the software I have in the car is tuned for 100oct. I use an OBDII tool to scan for timing retard (or correction factor) and adjust it accordingly to run on regular pump gas through another program I have. For those wondering why, the 100oct mapping allows for max potential power from my setup (more aggressive fueling/timing).
                        So I am always in search of the highest octane pump gas around, since I can't justify throwing down ~$80 a tank for the 100; atleast not all the time.
                        When 93/94 oct pump was available to me I swear the car drove smoother; probably just placebo. Oh well, guess I'll deal with the 92 sauce.
                        I'm going to UND, so I'm in GF most of the time for those who asked.
                        2008 Audi A4
                        2000 Audi S4
                        - Sold
                        12.4@116
                        • Seven1S Offline
                          Seven1S Offline
                          Seven1
                          My car is tuned for 91 but I still try to find higher, most BP's have 92 and that's been fine for me. I have tried the premium from Brady's in Moorhead and noticed a slight difference in performance for the better, but it may have been in my head.
                            remap for E85. I'm not kidding.
                              BlueSRT0483
                              Don't you need special fuel lines for that?
                              I could be wrong...
                              2004 Dodge SRT-4
                                ticklemedaly
                                I could be wrong...
                                not just lines. E85 vehicles have also redesigned injectors, regulators and even pumps to handle the different fuel qualities. Typical repairs that I have done for vehicles that have been running E85 that were not designed for it is replacing eveything but the hard lines. Plastic lines have been replaced too in the past due to the corrosiveness of the fuel. Major thing that gets damaged the most are the injectors.
                                  They recommend you replace the soft fuel lines, however this has been proven to be less of an issue in recent E85 formulations. Really all you need is injectors that are capable of flowing about 30% more than stock and an ECU capable of adjusting to the change.
                                  I made the switch this past summer and will never go back.....race gas for less money than 89 octane? HELL YEAH!!
                                    You Lie, I think you could afford it....
