  4. Something doesn't look right....
14 Posts 11 Posters 888 Views
  • XJHEADX Offline
    XJHEADX Offline
    Easy way to lower compression.
      Yep, it lowered that piston enough that the skirt hit the crank. :icon_cyclops: I wonder how long it's been like that. LOL
      • fallguyF Offline
        fallguyF Offline
        fallguy
        The funny thing is it ran just fine!! I checked compression it was good. It didn't make any knocking sounds. Glad I decided to take the motor out and check it out! I'm going to start building my other block this winter with the good stuff as money allows. I will take the rods out of other motor and replace this one or all six...It only has one bent rod. I'll have some new slicks this year and cams, so I won't need to spray the nitrous shot the whole track. For what it's worth I only sprayed the 100shot I think once or twice. That was on top of 35psi!! 🙂 No pain...No gain!
        1990 Ford Probe GT 2jz RWD
          o my...
            nice!
              That rod definitely felt some pain.
              :icon_albino:
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                Haha, that is awesome.
                  OMG!! You got pretty lucky Matt. Time for some upgraded rods. I wouldn't mess with using stock ones at this level.
                  • dubbsyD Offline
                    dubbsyD Offline
                    well, there was the .004 😛
                    • fallguyF Offline
                      fallguyF Offline
                      fallguy
                      Wes you can make a check for $1500 payable to me if you please. 🙂 New rods aren't cheap. I will get them for my other block. I really want to run an 8 on a stock block. I think with cams, new slicks etc I should be able to run less nitrous to get the same results. I think it's the nitrous that caused the pain to that rod.
                      (I'll even put "Weshole" on the window somewhere. 🙂
                      • thurmanmermanT Offline
                        thurmanmerman
                        thats nuts... good thing it didn't go BOOM!!!
                        > Parker;299126 wrote:
                          Wow you got lucky! good luck with your goal on the stock block and have fun building your new motor!
