  4. fucking tires !! Fucking pot holes!
24 Posts 14 Posters 534 Views
    yeah, it was a rear so my steering wasn't affected to bad... the intersection of interstate i was on didnt have a shoulder either...
      only if honda made tires...
        they'd be overpriced, underpowered and after a little while you'd start getting sweet rust spots in them
          shitty luck...shoulda took pics of the coffee spill
          • Turbo5OhT Offline
            Turbo5OhT Offline
            Turbo5Oh
            jim how often do u check ur tire pressure? i had problem with a car with 17's on it a fews years back it also had 35 series tires on it.
            this kid kept coming back blowing out tires like every month, basicaly what it came down to was that all 4 tires had slow bead leaks but becuase they were such a low profile tire u couldnt tell by looking at them and after driving on them low they would heat up and blow out the side walls of the tires
            typicaly tires dont just blow out like that with out being drivin on low or hit something large/sharp at high speeds
            idk either that or quit hitting shit on the road?
              Well, these 17's I've only blown out two... There are pot holes everywhere, and I usually drive 80ish on the freeway, but I didnt think I hit anything too huge...
              I blew out a 19" one and fucked the rim up, I fucked up a tire on my mercedes as well...
              I check the pressure every once and while, and it doesnt seem like it's lost alot or anything...
                The kid driving a bimmer and mercedes calls honda's overpriced....hahaha
                  They are... for what you get.
                    Last winter I got 4 flat tires in 48 hours. Thanks to shitty old sun beat tires, and no I don't have any idea why they all decided to go at once. :icon_shaking2:
                    I feel your pain Jim!
                    • 2slo50h2 Offline
                      2slo50h2 Offline
                      2slo50h
                      Jim wrote:
                      it happned on the intersection of 35W and 62. It was scary as hell i was going like 80
                      I was probably driving right on past.
                      Next time I'll wave.:icon_cheers:
                        5 flats in a year ouch, this is when its time to invest in run flat tires ha
                          Haha, run flats aren't options on any of my cars... woudln't want them anyways
                          • ColinC Offline
                            ColinC Offline
                            Colin
                            Get rally rims, then do the tire in tire thing...
                              Run flats suck. If you get a flat and drive even close to the 50 or so miles their rated at, the tire is junk anyway. So, it not worth it to pay the extra for them. Not to mention, they still are just as prone to picking something up and creating a leak and there's even more stringent gudelines to repairing them. And finally, they are some heavy motherfuckers because of all the reinforcement to cope with the rigors they were designed for hence you'd loose fuel economy and performance because of the drag.
