  4. new vtec (avtec)
new vtec (avtec)
30 Posts 15 Posters 1.1k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    That is amazing. The idea of a variable length intake manfold is very smart. Shorter in the low RPM's for more TQ, higher in the upper RPM's for more hp. I hope this catches on with other car maakers.
    There is a video somewhere that is pretty cool.
    • killer69penguinK Offline
      killer69penguin
      new toy for torbert......
      1993 3000GT VR4
        REPOST
        http://www.fargostreet.com/forums/showthread.php?t=9738
          killer69penguin
          but its a good repost!
          1993 3000GT VR4
          • ruthless351R Offline
            ruthless351
            AAAWWWWW! Not another VTEC!!!
              continuously variable...gheyness...i want my v-sweetness all at ONCE y0!!!one!!!eleven!!!!
                Yamaha has this same technology on the 2007 R1. No vtec cams, but the variable length intake runners.
                • GarageAlchemistG Offline
                  GarageAlchemist
                  I believe shorter runners would make more power up top, and longer down low?
                    GarageAlchemist
                    • 94NDTA9 Offline
                      94NDTA9 Offline
                      No.
                        The idea has been used before, but obviously not as technically advanced. There are a few cars that came with butterfly valves that used different runners at different RPMs etc.
                          KA's had them, well at least mine did.
                          • 94NDTA9 Offline
                            94NDTA9 Offline
                            Explain. Like they had one butterfly valve open at lower rpms, and another on a different length runner tha would open at higher RPM?
                              Yes sir. There is an H22 sitting here with that same system. JDM 4G63's had them as well.
                                killer69penguin
                                obviously they know what they are doing......with im sure millions of dollars in research and all
                                1993 3000GT VR4
                                  The GSR had secondary butterflies stock as well.
                                    werd^^^...stock it's kinda like listening to two "mini-vtecs" so to speak...mmmbaaaaDAAAAA...that isnt meant to be sarcastic rice like I normally would...Thats what it actually sounds like.
                                      thrash
                                      I wish there were some engineering drawings showing how this system worked. The variable length intake runner stuff isn't new.. although i can't think of an application off hand.
                                      The continuously variable valve lift and cam phasing are interesting and a definite departure from how VTEC used to work. Note that AVTEC is not the first introduction of continuously variable valve lift into a production engine... Valvetronic from BMW has been doing this since 2002 or so, and I wouldn't be surprised if they weren't the first.
                                      I've heard that F1 engines use pneumatic valve trains.. i wonder if/when we'll see that in production cars. If anyone has links to drawings of how these systems work, that'd be fantastic.
                                        Ford has had butterfly valves in the intakes on a number of their motors. From the 2.0 SPI to the 4.0 SOHC to the 4.6 DOHC
                                          Ford sucks though.....
