  4. rock my ride contest
34 Posts 19 Posters 1.7k Views
  • sitn2loS Offline
    sitn2loS Offline
    sitn2lo
    ok i was just tryin to get the right info so i thought i would ask on here
    Yukon Denali on 22's
    • C Offline
      C Offline
      CivicEX7777777
      Congrats to a great guy cant wait to see the final project!
      2007 Pontiac G5
      2007 Yamaha C3
      2002 Oldsmobile Alero
      1994 Nissan Sentra
        Gundar1;181789 wrote:
        I could do a full JDM conversion to my car, painted and everything for 10k, which includes like coilovers, and other stuff.
        Maybe a few body pieces and stuff...what do u consider full JDM conversion...as the motor alone would probably cost half that.
        • M Offline
          M Offline
          musthavemuzk
          can't wait to see the end result.
          Monty
          14.59 at 94.85 still stock
          www.pbase.com/musthavemuzk
            ya, and good coilovers are over 1k, paint isnt cheap, unless you do it your self........
            • FG2F Offline
              FG2F Offline
              FG2
              Cost is $3300 + shipping....
              The JDM front end for the 4 door Si isn't that much money. Reason being is that the CTR from Japan has the same front end as the Acura CSX in Canada. So if you source out the fenders, hood, front bumper, fog lights, headlights and cha ching you have the "JDM" front end.
              "JDM" CTR
              http://images.google.com/imgres?imgurl=http://www.rsportscars.com/foto/11/typerjdm07_01.jpg&imgrefurl=http://www.allhabit.com/thread-120276-1-1.html&h=768&w=1024&sz=66&hl=en&start=13&um=1&tbnid=NOT5QaoqRBgglM:&tbnh=113&tbnw=150&prev=/images%3Fq%3D2007%2BJDM%2BCTR%26svnum%3D10%26um%3D1%26hl%3Den%26safe%3Doff%26sa%3DN
              "Canadian CSX"
              http://driving.canada.com/07photo/acura/csx4dr-premiumnavi.jpg
              The list of parts are (taken from a guy that did the conversion):
              "1. HOOD
              a) hood insulator (it comes with it's own clips)
              b) L + R headlight seals ... those are rubber pieces that attatch to the left and right corners of the hood where it meets the headlight
              c) ur warning lables that go under the hood
              1. L + R FENDERS
                a) L + R bumper brackets ... those attatch to the fenders. You need those because this is what the bumper attatches to at the back corner of the headlights/ front corner of the fenders... you will need to reuse the 1 screw on each side that's on the stock bumper brackets (or u can get new ones)
              2. BUMPER
              3. GRILL ... mugen or stock jdm civic / csx crill ... if using csx / jdm grill u'll need a few extra mounting clips for where it attatched to the top of the bumper... i think 3 but i'm not soo sure since i'm using a mugen grill.
              4. RADIATOR COVER/COWL
                a) extra mounting clips as this one uses 3 extra clips ... part # 91505-S9A-003
              5. L + R HEADLIGHTS
                a) L + R headlight brackets ... those are needed to attatch the headlights to the frame as well as to attatch the bumper to the bottom of the headlights.
                B) 4 extra bulbs ... can't remember the bulb number but u'll want those bulbs + sockets ... 2 of these bulbs are ur park lights so u may want those or else u won't have park lights ... the other 2 are city lights which just look cool when ur headlights are on ... u have to wire them into ur harness accordingly.
                i) the park ones get wired into ur turn signals via 2 wires... so they light up when u stock park lights are on but they don't blink ... they are basically side markers.
                ii) the city lights get wired into ur low beam ...
              6. FOG LIGHTS
              you will have to reuse ur stock screws/bolts. they are all the same.
              all 10mm bolts with the exception + 2 philips screws for the bumper brackets + 2 philips screws that attatch the bumper at the corners
              side item ... u'd have to remove ur wipers and u need a 17mm socket for that
              That's everything you will need for a perfect conversion without any missing pieces and a perfect fit ... no modifications of any kind. 100% bolt/snap on."
              Congrats to the RX8 owner, and I assure you, this thing is gonna be amazing when it is done.... Less than 2 weeks and counting until the unveiling!
                "JDM" CTR
                "Canadian CSX"
                "1. HOOD
                1. L + R FENDERS
                2. BUMPER
                5. L + R HEADLIGHTS
                6. FOG LIGHTS
                Full JDM conversion to me means also the motor, interior, rest of the body panels, etc....otherwise it's a JDM front end conversion...i'm guessing that's not even RHD either
                • Gundar1G Offline
                  Gundar1G Offline
                  Gundar1
                  Ok, the front and rear end conversion would cost around 10k with 5k left over you could get a good start on the interior.
                  http://www.8thcivic.com/forums/showthread.php?t=50692
                  Re: Front bumper
                  Quote:
                  Originally Posted by Gundar1
                  Hi, Where did you order your front and rear bumper from, and if you dont mind, how much was it?
                  thanks, adam
                  Hi, I didn't order just the front and rear bumper alone..I purchased the complete jdm front end conversion and the rear end conversion, and i added the Mugen kit. it was abotu $8,000 total in parts. thats everything
                  Nasif
                  plus paint
                  EVO
                    who cares?
                    • itRfanI Offline
                      itRfanI Offline
                      itRfan
                      congarads to the rx8 cant wait to see what it will look like!!
                      -weshole
                        Re: Front bumper
                        thanks, adam
                        Nasif
                        plus paint
                        Kid stfu ur dumb....like i said before still not a "full jdm conversion"
                          does that 8k include shipping, painting the parts to match the car, installation? and you said for 10k you could, nothing about the other 5k.
                          k I am done with this thing.
                          • Gundar1G Offline
                            Gundar1G Offline
                            Gundar1
                            Oh, yeah full exterior conversion sorry, and iam going by what he told me. and yeah im dumb
                            EVO
                              and again who the fuck cares?
                              • Gundar1G Offline
                                Gundar1G Offline
                                Gundar1
                                Nobody 🙂
                                EVO
                                  exactly 🙂
                                  • JN210J Offline
                                    JN210J Offline
                                    JN210
                                    oh dang missed my chance big time with this, could've entered my nissan Z31, lol
                                    *1989 Nissan 300ZX Z31 *
                                    > DelSlow;262050 wrote:
                                    > I like the new JN210
