  4. Car smokes....
Car smokes....
27 Posts 10 Posters 1.6k Views
  • StangerBanger96S Offline
    StangerBanger96
    Did one of your calipers seize up so you have some pad rubbage?
      i always forget that you switched to the dark side sorry man
        injector o-rings? if you touched them did you lube them?
        • XJHEADX Offline
          XJHEADX Offline
          When was the last time you checked oil prior to this event?
            he just put the motor in, so I hope he just checked it. lol.
              Oil and everything is fine...it isnt a caliper or anything, It's engine related as it pours out the exhaust. I put different injectors in that I knew worked, as they were off my LS motor. I went through a tank of gas from fargo to fergus and to elbow lake and back from fergus, probably 150 miles tops. Roughly a little more than 20 or so mpg...Idk if it could be my ecu is fucked up or what. It used to act like this when it used to be in, but it didnt have the smoking. My compression when I tested it ended up being 180 170 155 160...probably not the best, but it should be enough where that isnt the problem. And Hjermstad, i'm kicking myself everyday for going back to D series, lol....I miss my torque. So far I havent burned any oil or coolant, and There's no coolant going into the oil at all. I think it's just running very rich and can't figure out why or how to fix it...
              • BookemB Offline
                BookemB Offline
                Bookem
                Was it over full before the trip though? i'm thinking that's what Bill was treying to say as well. I have seen that happen with as little as 1 cup over full on a 4 cylinder running over 3-3.5k rpms.
                Legacy GT
                Gmc Suburban
                Hallorann: Fargostreet?
                Hallorann: No, I ain't.
                  U mean the oil? I don't think it was...had 4 quarts in it...and shot a bit out trying to start it, just cause I was missing a valve cover stud at that time...
                  Kinda off hand but while I was working on it some other cool projects were going down in the shop I was at. Josh went from T's old hatch running to taking the D series out and swapping a gsr into it in 4 hours and had it running. And our other friend just finished up his solid axle Toyota crawling truck. Got a trail ride with that...steep enough inclines where tires were coming off the ground and practically sideways at points...
                  • D S ohMD Offline
                    D S ohMD Offline
                    D S ohM
                    Only one solution to your problem. Sell the Honda and buy a DSM.
                    I wanna go fast!
                      ^ I think I just threw up in my mouth a little...a broke honda is always better than a dsm...
                      • GarageAlchemistG Offline
                        GarageAlchemist
                        thats a horseshit idea Ohm.
                        97 GTi, 03 KJ
                        • D S ohMD Offline
                          D S ohMD Offline
                          D S ohM
                          I love the idea. DSM FTW...they are gonna make a comeback. I know it.
                          I wanna go fast!
                            Just keep telling yourself that...I think most of us have realized there's better ways to go...i've seen more dsm owners convert to honda's than the other way around...
                              D S ohM;188289 wrote:
                              they are gonna make a crank walk. I know it.
                              fixed it for you.
                                ^ Oh now that's pwnage....i'm pretty sure hjermstad's civic > ohm's dsm in every category imaginable...but seriously guys....back on topic...anyway I can lean the thing out or something...
                                • BookemB Offline
                                  BookemB Offline
                                  Bookem
                                  What color was the smoke, and have you checked your plugs yet to see what they look like. Pics are good too if possible.
                                  Legacy GT
                                  Gmc Suburban
                                  • 3_Series3 Offline
                                    3_Series3 Offline
                                    3_Series
                                    You could try using a wideband.
                                    2002 Subaru Legacy
                                    1993 BMW 325i (sold)
                                      or be really cheap and get a volt meter on the signal wire of the o2
                                        Just read your plugs.
                                        • D S ohMD Offline
                                          D S ohMD Offline
                                          D S ohM
                                          Just like 90% of cars on the road are better than your Limited Edition CRX Bondo. I say Limited because it looks like your passenger quarter is gonna slide off. Then the rest of the car will fall apart piece by piece.
                                          I wanna go fast!
