  4. chip reader/burner
chip reader/burner
17 Posts 5 Posters 803 Views
    Hey, who has one? I need a set of chips copied. and then a bin(i think the right name) file for my computer. chips are27SF512
      hjermsted
      I think GSR has one as well
        i know they have one. i pmed GSR on sat, no reposnse
          I do too......
            I looked up the chip but couldn't find anything. Problem I have is my burner isn't USB so I cannot use it on any of my PCs. None of my PCs have parallel ports anymore. ;(
            Anyone want to buy a pocket romulator and burner?
              how much do you want for it?
                i have one but have no idea if those chips will work with my burner? ive never heard of the burn1 for nissan ecus.
                cmk lets make this thing work!
                  Give me a call when you want to do it
                    alright, busy tonight?
                      not after 6pm
                        Those are the same chips i have run in my ecus so it should work with the burn1 i just don't know what program you will need.
                          I just need two chips copied. wont the same program you use to do chips work for mine?
                            The burn1 will read them and then could probably copy them without putting them into a program, but to actually get the bin that you could save to your computer i would guess that you will need whatever program you are using for yours.
                              the guy i am buying my next tuning system talks about the burn1 and has some write ups on it.
                              http://www.sr20forum.com/calumsult/164481-how-burn-rom-moates-burn1.html
                                HMMM
                                seems the same. if my and cmk ever get around to getting mine to work ill try and help ya out
                                  haha, you lazy ass.
                                    after i get my car buttoned up for winter and towed home, ill try to help.
