  4. parts for sale..
parts for sale..
24 Posts 8 Posters 1.7k Views
    ok i have some stuff i need to get rid of and i don't have a honda anymore so her it goes.
    i can get pics but not right away, if you want to take a look or needs a pic asap call me/pm me
    701-238-4855 matt
    $100 greddy type R bov used but in good condition.
    $40 dsm 450cc blue top injectors, used but worked great in my civic. comes with stock d15 o-rings bored out to fit the injectors.
    $100 ss tig welded log manifold that i made as a prictice peice. it is set up for a t25 from a sr20, internal gate, NO warrenty NEW
    $250 exedy stage 2 clutch, 3 puck cerimatalic disk, for the 90-91 small shaft trans only. (integra or jdm b16 trans) NEW
    $200 b18a1 motor with fresh head right from the machine shop. new seals, the motor is taken apart but the price reflects that.
    **$90 **ls b18a/b arp head studs NEW
    $25 ls b18a/b arp rod bolts NEW
    $50 2g dsm side mount intercooler modified to fit a crx
    $50 dsm walbro fuel pump w/ install kit pretty sure it's for a 1g
    **$1500/OBO **90' ford probe gt turbo, red, leather seats(ripped in spots), atx-mtx swap, act 2100 clutch/ fidanza flywheel, new axles, intrax springs/kyb struts, trans is FIXED...
    bad:
    -has hail damage and a salvage title from the hail.
    -needs and exhaust
    -heat only works in the center and feet vents. i never had a problem all winter with the vents stuck.
    $100 2.5" exhaust can be made and put on.
    i have more stuff that i will add later.
        bump
          whats the manifold for i might haev someone interested.
            i made it for my crx back when i was at bi. i still need to dril out theholes for cyl. 2 and 3. but that will take 30 min. i was able to fit a 2.5" dp with a/c also, fyi it is for a d series.
            • no_slow_clapN Offline
              no_slow_clap
              exedy clutch. will it work for sure in my trans (b16 trans w/ lsd)
              EVOLUTION VIII
                it will not work for you
                  no_slow_clap
                  Damnit!!
                  EVOLUTION VIII
                    yeah it is a small shaft disk, and i think the pressure plate is different
                      i'm pretty sure they are... i'm pretty sure the only cable clutches that will work in a hydro trans are out of the da gsr trans ys1...as they're basically all hydro internals with a cable case...
                        well from what i know is that a 92-93 cable disk will work but not the pp, in a hydro app, sence they changed the spine count and size of the shaft in the trans.
                          Bump for a pimp seller, would buy again ++
                            bump
                              bump....
                                damn i really wanna buy that manifold and ghetto boost my four door... ( attempting to talk myself out of this)
                                  dude i have the part to do it?.... lol
                                  • 9 Offline
                                    9 Offline
                                    91teggy
                                    What do you want for the head off the b18a1 or the whole motor have to go
                                      $100 for just the head, it has new valve seals, and cam seals are sitting next to it.
                                        bump
                                          Buy from this man so he can afford hot asian hookers
