  4. Honda Swaps
Honda Swaps
28 Posts 10 Posters 1.2k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    Im wondering about a few swaps for my civic. Is a b20 swap posible? Whats the pros and cons on a b16/b18 hybrid? b16/b20 hybrid?
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      Depends on what you want really.
      LS/VTEC somewhat cheap, makes decent power.
      CR/VTEC (B20/VTEC) also somewhat cheap, makes good power
      B20 = slow
      B16 = waste of time
      B18A/B = good bang for the buck
      B18C1 = very good time, kindof pricey
      B18C5 = very good time, even more pricey
      Downsides of anything with the B20 is that it is one of the weakest b series honda motors from the factory. Thin sleeves, weak cranks, horrible rods.
      If you are looking for a GOOD bang for the buck swap and dont mind not having vtec I would just go with the straight LS swap. You can always add a vtec head to it later on down the line.
        harwood39H Offline
        harwood39
        OK. My next questoion is whats better, JDM b18a or JDM b18b? I dont care for the b18c because its too much.
        Fargo, ND 58103
        701-429-3686
          how bout h22 or doesnt that work?
            How about just save up $$$ and then buy stuff?
              harwood39H Offline
              harwood39
              I haqve enough money for a b18 swap. but it has to be a b18a or b18b. I cant afford a b18c.
              Fargo, ND 58103
              701-429-3686
                You have enough for a b18?????? How so?
                • NickBN Offline
                  NickBN Offline
                  NickB
                  get a B 18C5
                    there doesn't seem to be much difference between the b18a and b18b, probably just something within the head. find yourself a b18a/b in a junkyard, then bolt up a turbo. or... get a b18a/b block drilled and set-up for vtec and buy a vtec head. with bseries honda engines, options are virtually limitless
                    • E Offline
                      E Offline
                      eg6_vx
                      i'd get a OBD1 b18b out of a 94-95 integra then turbo it later when you get more money. or just save more now and get a b18c1 because they are definately lots of fun
                      Kyle Morrow
                      Tintmasters Motorsports
                      89 crx hf
                      01 s2000
                      06 cbr600rr
                      N/A is best
                        I vote b18b.... not a huge difference between the a and b... only like 10 hp, but 10 hp is 10 hp...
                          How much are you looking to spend on a complete B18B swap? I just happen to have a complete swap out of a 1994 Integra LS. I may be willing to sell it if I can't sell the whole car (92 hatchback I'm selling).
                            harwood39H Offline
                            harwood39
                            I can get a JDM b18b2 OBD1 swap from total jdm for around $900. I will end up installing it my self. the b18b2 from them is vtech.
                            Fargo, ND 58103
                            701-429-3686
                              NO
                              it is neither a phone (vtech) nor a vtec motor if it it a b18b, and for 900 you would be getting just the motor... no axles, no ecu, no tranny, etc, etc, etc....
                              reputable companies that sell the COMPLETE swap go for closer to 2,000
                                harwood39H Offline
                                harwood39
                                go to totaljdm.com they sell everything with it. Tranny, wiring, ECU, etc, etc, etc...
                                Its 875 for the swap, than 150 for shipping
                                Fargo, ND 58103
                                701-429-3686
                                  kindly show me where it says axles, ecu, wiring, tranny, etc, are included?
                                    it just says halfshafts and like 2 other things...thats not a complete swap by any means...
                                    can i look at that $400 integra with the b18c?
                                      Some things I think you need to seriously consider:
                                      1. Are you 100% sure you have the technical knowhow to complete an engine swap. Are you REALLY sure... Hmmmmm
                                      2. Realistically, do you have the money to do a swap right? $1025? Hmm... Engine swaps would be going on like mad if everybody could do it for that.
                                      3. There's a good website for all of your questions: http://www.honda-tech.com SEARCHING it before asking questions is always helpfull... 99.8% of the time the questions have been asked / answered.
                                      4. As you previously said, your car is totally stock besides a cd player, speakers and some removed exhaust resonators, perhaps it would be wise to start somewhere a little bit less drastic then an engine swap so your first project. A) Where would you work on the car? B) What are you going to be driving in the mean time? C) How much power are you actually going to gain?
                                      In the past week, you've made several threads asking what you should to your honda, you've inquired about engine swaps, you've talked to many people about the same stuff more then once...
                                      If your asking these questions, I dont think you should be attempting an engine swap, but don't get me wrong, I could be way off:
                                      "haha, no thanks on selling it, i just got it on monday. should i do exhaust before turbo? when should i do a short shifter? Im new to the honda world so i need to hang out with some honda guys."
                                      "Where can i get this intake temperature "chip" that wannabe is talking about?"
                                      From reading your posts, I can infer that you don't really know what route to take yet with your car. Don't worry! It doesnt always come right away, you spoke about doing visual mods, then turbo, then swap... Just save up the money and do what you want!
                                        HERE IS A DIRECT QUOTE FROM TOTALJDM.COM:
                                        "Title: Longblock Only!
                                        Tip/Fact: We get alot of people asking us what is included. Well, this is a longblock, so no transmission, ECU, wiring or axles. All the components such as the distributor, alternator, plug wires, starter, etc... are present."
                                        So there you have it... there's no way your going to be doing a swap for $1025... If your spending that much anyway, why not consider the B16 that is already for sale in fargo that includes it all, plus mods, those mods + engine are worth ALOT more then whatever junk this company is selling.
                                          harwood39H Offline
                                          harwood39
                                          I have the technical know how to do the swap. I would do it out at my friends shop. I have a 96 taurus wagon that i would drive during the swap work. I have rebuilt a couple motors and redone wiring in a couple cars (1978 Jeep CJ7, 1964 Chevy Pickup hotrod). they may have been older cars but it still gives me the know how to pull a motor and drop one in.
                                          Fargo, ND 58103
                                          701-429-3686
