  4. Camaro Project
Camaro Project
17 Posts 10 Posters 1.1k Views
    all that just to pull an engine:eek:
    fun fun.............. I think it needs a big single...
      i know how to do a big single on those.......
        The engine done be broke. A nasty rod knock. I've got pics of the shitty bearing that I'll put up later.
        As far as a faster car, I don't think that is a problem. His shit doesn't even run. This engine problem is after having a clutch go out, chipped pinion gear and now this. lawlz Camaro FTL
          Wow, it sounds like your little brother has bad luck with cars! So is he paying you $40-$50 an hour for all your hard work?
              That bearing is from the #5 cylinder. :eek:
                domestics......psshh
                • z31Z Offline
                  z31Z Offline
                  z31
                  :icon_scratch: Looks like a spun rod bearing. Excess clearance or lack of lubracation.
                  CMK, how many miles on it?
                    Lack of lubrication. The #5 bearing was the one that is fawked, and the #7 bearing turned out to be spun.
                    120k or so on the motor.
                    My brother brought the car home one Friday night with it knocking like that. Earlier that week I was helping him with a squeaky belt tensioner and a coolant leak and ended up adding 3 quarts of oil to it. He done blowed it up. 3 quarts low + cold starts + teenage driver = dead LS1
                    • nonamekidN Offline
                      nonamekidN Offline
                      nonamekid
                      Thank goodness they put screens on the oil pickup tube. That looks bad.
                      1990 240SX coupe
                      1992 Mazda MX-3 GS 2.5 swap
                      1983 VW Rabbit GTI 2.0 swap
                      • ruthless351R Offline
                        ruthless351
                        I think your bro is lucky you r takin the time to help him. Slap him upside the head for me for not checkin the oil once in a while!!! 3 quarts!!!!!!!! low!!!! Stupid is stupid does!!
