  4. speaker loudness
speaker loudness
14 Posts 6 Posters 709 Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    I put in a new aftermarket speaker in the front door of the sentra today....I have one new one and one old one now....my question is why does the factory one have like twice as much bass? They are the same size, and the new one handles 100 watts. Is that why? Bass doesnt kick in until later?? Does it matter that I have one factory and one aftermarket? Any ideas, or are aftermarket speakers just like that?
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
      the way the speaker will respond is dependent on how much power you're giving it in relation to how much it can take.
      your radio is probably putting out... 10 watts rms (constant) to the factory speaker which is rated for 8-12watts rms. however, the aftermarket one is rated for 40-60 watts rms (peak 100). this means your factory speaker is operating more in it's efficiency range than the aftermarket one. make sense? if i remember everything correctly from when i was into stereo equipment...
      • M Offline
        M Offline
        mym6
        Because factory speakers have a difference frequency response compared to your aftermarket speaker. Your old speakers are able to reproduce the lower frequencies better than your aftermarket speakers. It's about how the speaker is designed. But you will also note that over time (and as it gets warmer out) the upper and lower frequencies will continue to improve out of your new speaker.
        • jct_4628J Offline
          jct_4628J Offline
          jct_4628
          takes a while to break in you mean mym6?? And Thats what I was guessing about the watts...thanks for the info.....would it make a difference if I put in both new speakers? I wouldnt think that it would but you never know...
          Jason
          -06 WRX
          -95 CBR 600F3
          701-541-2568
          • My NOvaM Offline
            My NOvaM Offline
            My NOva
            to get more power out of the after market speakershave u tryed to preamp them by getting additional amps that would help out alot for the power u are seeking and what type of speakers did u use are they cheapies from walmart???
            Hey Tina come get some hamm
            • jct_4628J Offline
              jct_4628J Offline
              jct_4628
              no, I bought 2-way pioneers and I know that I can use an amp...I have installed many a car stereos and speakers. And I would rather buy subs and amp those and then just turn up the treble on the in-car speakers rather than amp the in car speakers.
              Jason
              -06 WRX
              -95 CBR 600F3
              701-541-2568
                lets see, there are a variety of reasons that the aftermarket speaker isn't producing the amount of bass the stock one is. It could be that the aftermarket one is crossed over internally (or even externally) to block the lower frequencies. Another thought is that it may not be exactly in phase w/ the OEM unit so the bass seems diminished on that side of the vehicle due to cancellation (not likely, you'd probably notice this happening in both speakers, rather than one). Another thought, is this a "premium" OEM system (BOSE, Infinity, etc...)? Sometimes they have matched drivers to work w/ the crossovers in the OEM amplifiers, for example a crossover that is designed for the 8 to 16 ohm OEM speaker will be several octaves off for a 4 ohm speaker. Its also possible that the aftermarket speakers didn't seal to the door as well as stock did and therefore the rear wave is cancelling out some of the bass frequencies due to that. You could try simply switching the polarity on the pioneer unit (switch the posi and neg terminals around) as this MIGHT have a small affect on bass and/or imagining.
                  I really should just write a book about stereos and frequency response...or at least a LONG post like I did about the various shops in town
                    Wait, Vance Dickanson already wrote THE book on this: The Loudspeaker Design Cookbook. A must read for all aspiring speaker system designers IMHO.
                      i think i've seen that book, as well as rip-offs
                      to me... the way that sound travels just kind of seems like common sense, difficult to explain
                        right, the way speakers resonate is common sense to me to, however there is SOOOO much more to speakers than getting the phase and imagine correct (as I'm sure you know). Based on the Thiele-Small parameters you can determine what type of enclosure a given woofer will sound good in b4 you cut the first piece of MDF. It's really amazing to think how much speaker technology has come along in the past 15 years. When I was first getting started a guy by the name of Mark Fukuda held the world record in SPL w/ a 153.6 in a bright yellow 1989 Chevy S10 Blazer (one of the cleanest installs I have seen to date actually). Now, just about anyone can go out and buy a system that will be in the 150's for SPL for minimal money, and to really compete for a world record (unlimited power class) you need to be able to get into the HIGH 170's if not 180's dB. The point I'm getting at here is that with the advances in technology of the past 10 years there are literally hundreds of resources available to help you build and design a kick ass stereo system. My favorites are the Loudspeaker Design Cookbook, LEAP enclosure modeling software from LinearX, LMS from LinearX, and my Mobile Dynamics coursework books.
                        Another tip for those of you contemplating competition (non-SPL) is use the least amount of speakers you can for sound quality. A good pair of 6 1/2" coaxials in the kickpanels and a pair of tens in a sealed enlcosure in the trunk might win you more than you'd ever imagine.
                        • jct_4628J Offline
                          jct_4628J Offline
                          jct_4628
                          so what do you suggest I do with the open space around the aftermarket speaker? The factory speaker had a metal plate on it that made the oval speaker round, so now the aftermarket oval speaker has a gap on top and bottom. Anything I can put in there to help out? And tjamz, u just talking about switching the pos and neg on the speaker right?
                          Jason
                          -06 WRX
                          -95 CBR 600F3
                          701-541-2568
                            I'd put a 1/8" masonite baffle in there to seal up around the gaps (use the plate from the OEM speaker to create a pattern to cut the baffle) and yes, just switch posi and neg...see if it makes a difference.
                            • bluejaysB Offline
                              bluejaysB Offline
                              bluejays
                              show off 😛
