  4. No more BP's is North Dakota
83 Posts 22 Posters 3.4k Views
  • M Offline
    M Offline
    musthavemuzk
    not sure what to think of this.
    i know i run BP 92 in my GP as often as i can. some of it is non oxy some is not. and if i see 10% ethanol added i skip over it. so i always keep my eye on pumps as i am driving around so i know where i can get gas that i like. as my GP def runs better on BP 92 than anything else. as i said it is usually the non-oxy version.
    BP here in TRF (non-oxy), the BP down the road from bradys in moorhead, BP down the block from tintmasters in GF, BP south of DL on 59 (has non-oxy or just 92), BP in ames ia (took me some driving to find a station that had 92 at home), maple grove has a BP that is 92,
    i drove around one night taking pics of pumps. some were labeled 10% ethanol added some were not. only found the one pump with 92.
    i know things change. i remember when i dads 68 camaro ran leaded gas and unleaded was taking its place. there was alot of concern about how cars would run and power and so on.
    Monty
    14.59 at 94.85 still stock
    www.pbase.com/musthavemuzk
      Monty, look at the link I posted earlier. about enthonal in the gas.
      • M Offline
        M Offline
        musthavemuzk
        well that just sux.
        i forget which forum i found it on, but there was linkage from MSRA about stations that sell non-oxy gas in MN for the street rod crowd. MSRA(minnesota street rod association)
        will see if i can find that link.
        Monty
          why does E10 suck?
          • M Offline
            M Offline
            musthavemuzk
            well as someone else pointed out about seatbelts. it should be my decision to wear them or not. i do not like being told i have to wear them. yes some get saved or at least reduced injuries, but there are also some that are killed due to them. so for me there is no proof that i should wear them.
            same goes for E85. there is no proof that it is better. in fact there is more proof that it is not better then regular gas. as in it takes more of it as compared to regular gas. as well as it really does not cost less and is not as environmentally friendly as once was led to believe. mpg's go down compared to regular gas. typically you have to change some items in the car to run it. yes it is renewable. but at the expense of what? use the corn and there is a chance food prices go up. how about the coal or other fossil fuels needed at the ethanol plants needed to make the E85? and the fossil fuels needed to transport the E85? how is this really better?
            now for E10. if this is such a good thing then why are the car companies not jumping on it and saying yes it is a good thing?
            why are gas prices not going down?
            if MN is required to run it and ND is not then why is gas prices the same on both sides of the river? why in IA was the gas prices the same when i was there over christmas?
            yes it is cool that you get the octane bump, but really where is the benefit?
            i know there are alot of cars that convert to E85 for the added power. but what about soccer mom barb. does she really care about that power? no she wants good mpg as she has to run johnny and suzy all over for practices and school events. she also needs to get to work and not worry about breaking down on the commute daily. she needs reliabilty and good mpg. and with noone saying ethanol is good for cars over the long haul why force it upon us? if it really does not cost less then why force it upon us?
            here is the linkage to the non-oxy info i found.
            how bout these guys. do they want to run E10?
            http://www.msra.com/NonOxygenatedFuel/Non-OxyFuel.htm
            http://www.msra.com/NonOxygenatedFuel/Non%20Oxygenated%20Fuel%2012.07.pdf
            on way to fargo saturday we went through GF. stopped at the truck stop by the settle inn. think this is off demers or gateway. this was on the ND side and they had 10% ethanol added on all the pumps on all grades of gas.
            Monty
              Ethanol takes more energy to produce than what we get out of it...Hemp would produce more but it's illegal...
                musthavemuzk;204618 wrote:
                same goes for E85. there is no proof that it is better. in fact there is more proof that it is not better then regular gas. as in it takes more of it as compared to regular gas. as well as it really does not cost less and is not as environmentally friendly as once was led to believe. Monty
                serisously? have you not read my earlier posts?? ethanol is FAR more environmentally freindly than regular gas. they even have used it in AGG stuff for a number of different things other than fuel becuase its water soluble.
                mpg's go down compared to regular gas. yes it is renewable. but at the expense of what? use the corn and there is a chance food prices go up.Monty
                and once again the only reason it gets such poor mileage is becuase all the motors that currently run it are set up to run both pure gasoline or E85. this mean the motor cant have a higher compression ratio needed to use the benefits of a higher octane fuel, because when they switch back to gas it'll denate to beat hell. switch to a different motor design and ethanol will produce plenty of power and get good mileage.
                and around here why would you ever bitch about the cost of corn going up? that means good economy for the farmers around here. if you would rather spend $.10 less on a ear of corn than have a renewable fuel source for years to come i think your priorities may need a readjustment.
                typically you have to change some items in the car to run it.Monty
                no you do not need to change things on your car to run it unless you run aluminum fuel lines(not typical). anything else will only stay cleaner from the alcohol, even rubber lines. gm themselves have done numerous tests where they run just one of their normal cars reflashed to run E85 and had no problems. in fact the fuel pump and rubber hoses were in MUCH better condition from the E85. the 15% gasoline lubricates the lines so they WILL NOT CRACK.
                how about the coal or other fossil fuels needed at the ethanol plants needed to make the E85? and the fossil fuels needed to transport the E85? how is this really better?Monty
                how can this be a good argument when the same money would just be spent to produce and transport any other fuel? your complaing about costs of transporting the fuel and producing it. both are things that money is ALREADY spent on, either way SOMETHING HAS to be moved why dont you just move the funds to a different truck or plant for a renewable fuel.
                the only difference is when corn is grown it uses CO2 to grow and produces clean o2, and when manufactured it produces feed for livestock, ethanol, and biomass to burn for energy and other things.
                now for E10. if this is such a good thing then why are the car companies not jumping on it and saying yes it is a good thing?Monty
                http://www.msnbc.msn.com/id/23033773/ they are
                the difference is the octane rating. the 10% ethanol both helps in cold weather and increases the octance FOR THE SAME PRICE.
                the benefit of a e10 is that your using 10% less fossil fuel. its RENEWABLE. thats the point of it. not to poduce the new cure all for a a fuel. they are trying to find an efficient way to cut down on fossil fuels. supply and demand, the less we demand fossil fuels the more surplus they will have and prices will eventually go down.
                also that 10% acts as "heet" for your motor so the fuel doesnt freeze up. you ever seen the price of heet that some people dump in every tank of gas? its like spending money on adding another 2 gallons of gas for 10 oz of ETHANOL, thats what heet is, alcohol.
                WHY WOULD IT BREAK DOWN OR BE LESS RELIABLE? you need to understad that ethanol does not hurt anything on your vehicle. its BETTER in most cases. and as far as mileage goes i refer to what i said about why ethanol doesnt get the same kind of mileage earlier. No one is saying its bad for cars other than the people that refuse to believe that its good, they do their own weak tests on it and dont take everything into consideration. ever seen an article from an actual car manufacturer doing actual R&D that says its bad? if it was BAD for cars they wouldnt have flex fuel vehicles and gm wouldnt be busting balls to convert.
                  my E85 game will end you
                    Also, the reason the gas is the same side on both sides of the river is economics. If 2 stores directly across the street have the same gas with different prices which one would you go to? Assuming that there is not benifits like free stuff for going to the one who has the higher price.
                    95+% would go to the cheaper one.
                    IMO, going E10 nationwide would do more good for the country(corn prices go up, dependance on forgien oil goes down) then having E85 available. My step dad makes his living off of corn and all that and used E85 for a month and never touched it after that.
                    • no_slow_clapN Offline
                      no_slow_clap
                      game...set...match.
                      EVOLUTION VIII
                      • M Offline
                        M Offline
                        musthavemuzk
                        while you sure said something there....it did not change my mind on ethanol or E85 at all.
                        so a car that can run on gas or E85 needs no changes to go between the fuels? i think you are wrong there. i have heard more than one person say they need to change some parts to do this.
                        but whatever.
                        you are still using fossil fuels to make E85. so where is the gain? same goes for transporting E85.
                        Monty
                          but whatever.
                          Monty
                          It takes fossil fuels to refine other fossil fuels also. The end result is you use less fossil fuels to produce/run E85 than you do to run regular gasoline.
                          The only thing I can think of needing to change to E85 would maybe be bigger injectors (~30% more fuel needs to be injected for the same BTU results)
                          • M Offline
                            M Offline
                            musthavemuzk
                            it takes more E85 as you stated to get the car to run, so does it really cost less to operate a car on E85 then regular gas?
                            as mpg would be less with E85. 30% less according to your figure.
                            i dunno mayb i am just being stubborn on it.
                            i know something needs to be done to help with the gas issues we have, but is this really the answer?
                            using foods to make gas will only make food prices rise. will take more E85 to get places than regular gas.
                            Monty
                              How many times does this thread need to be brought back from the dead...
                                change the world.... eat a baby
