  3. Run Your Mouth
  4. Swap.........avi?
Swap.........avi?
80 Posts 15 Posters 9.3k Views
    Pssshhhhht.... Jason and I have not had relations since January!
    P.s. Erik your attempt to stir up drama worked perfect.
      LupusSingularis;206590 wrote:
      Yup, obviously when I mentioned that he needs to get custom engine mgmt, it was so obvious that all he needed to do was "tweak" the Mazda computer a little bit. It's not like I was trying to point out that it wasn't as simple as calling the local corner parts store and picking up a "one-size-fits-all" tune.
      I can see it now: "Hi, I need a custom tune and a PCM to make a old Ford engine run in a Mazda that's 10 years newer." "No problem, we got 4 of 'em! -And you don't even need to dyno or anything, only nOOb's need that for such a cross-company, international, custom job. But really you can just plug the USB port from any new cellphone into your PCM and make Wookie noises into the receiver, that will write you a great tune. Make noises like a Shetland Terrier for a more aggressive tune, but you'll need to run premium fuel for that."
      I think most intelligent people knew that I was suggesting a dyno and custom tune to make his Ford engine run in the Mazda and even send info to his stock Mazda cluster, even with that difference in years. <u>I was pointing out that it might get a bit spendy with writing the code and all, to the point that it could be a complete project killer considering his budget.</u> At least I responded with something constructive, rather than "That post is stoooopid"
      FYI - intelligent means smart, sorry if I exceeded your vocabulary, oops, sorry again.
      And get your own SNAPpy comebacks instead of stealing mine waving it around flacidly.
      TLDR:icon_salut:
        Yeah your intro thread was very "constructive", and about as intelligent as your last post.
        Yeah, and "flacid" is actually flaccid with two c's..... fucking retard
        • LupusSingularisL Offline
          LupusSingularis
          I'm sorry that you're so familiar with the term "flaccid", I'm rather glad that I'm so unfamliar with it that I misspelled
          Every time that someone says "I don't believe in Ricers." Somewhere, there's a Ricer that drops to the ground, DEAD.
          • ErikE Offline
            ErikE Offline
            Erik
            F20C would be wicked hot. Too bad they're pretty spendy.
            Rotaries make me scared.
            They call me, old man...
              because they break!!... OH SNAP!!!! yeah i said it
                http://www.monstermiata.com/Monster_V8_Kit.asp
                  do you know anything about complicated engine swaps? <u>[U]OR</u>[/U] we could just ask what do you know?.... that seems like a better place to start... because from what i have read so far... you like to over complicate things... there are kits out there for a 2.3, and if people are swapping the 5.0 into them in sure a 2.3 would fit... and in a case like this you dont reprogram the miata ECU... you make a wiring harness to fit the 2.3 ECU( not that hard) and make it work with the swap car ( reprograming, resistors, you get the point)... comments? i can do this all day... so please, at least do a google search before you reply, and inform yourself about these sortof swaps so i dont have to point out the obvious... as you clearly need done...
                    weshole;206559 wrote:
                    What, swapping a SBC into a 7 is different? That's soooo 15 years ago. I'll give ya this.. you went with some nice go fast parts but originality........:rolleyes:
                    you make me lol
                      Man you lie..... that has never ever happened
                      :icon_scratch:
                        A lil off topic (imagine that).... But Parker, what rear diff are you running in the 7?
                          Parker;206623 wrote:
                          do you know anything about complicated engine swaps? <u><u>OR</u></u> we could just ask what do you know?.... that seems like a better place to start... because from what i have read so far... you like to over complicate things... there are kits out there for a 2.3, and if people are swapping the 5.0 into them in sure a 2.3 would fit... and in a case like this you dont reprogram the miata ECU... you make a wiring harness to fit the 2.3 ECU( not that hard) and make it work with the swap car ( reprograming, resistors, you get the point)... comments? i can do this all day... so please, at least do a google search before you reply, and inform yourself about these sortof swaps so i dont have to point out the obvious... as you clearly need done...
                          was this projected at me or the nooby... If so I know that there are kits for v8's, and I know people do 2.3's, but there is no need for these swaps other than shock factor of opening your hood. A LSx or a 302 isn't a wise choice, IMHO, To compliment the miata's inteded pusposes.... Altho a tube fram miata dragster with a beefy v8 in it would be sweet, or you could go with a 6 liter jag v12 like brainsboy on Miata.net...
                          http://forum.miata.net/vb/showthread.php?t=258649
                            Joel I do belive your wrong about the LSx swap. Those engines are nearly the same weight as the 1.6 in there. You loose nearly none of the cars handling capabilities. They are just an expensive and involved swap to do properly. So it's not for the faint of heart.
                              oops forgot to hit the "quote message in reply" it was projected at LupusSingularis
                                im using the stock one till the kinks are worked out of it... but by mid summer i will have a ford 8.8 in it... then comes a trans brake and some giggle juice 🙂
                                  Soild axle or IRS out of a thunderbird?
                                    solid.... not going to fuck around with another weak IRS...
                                      You're not gonna kill the 8.8 IRS out of the Thunderbird. They hold up tp the best that the best LS1-2 throws at it. And...... IT HANDLES with it.
                                        I never said anything about how much the motor weighs, wes. The fact is, the miata is a quick, Nimble car. I guess 300 ft/lbs of torque doesn't strike me as nimble. With a turbo setup, you aren't always in boost, there for you can still take a corner at a decent amount of throttle without killing yourself. I guess I might just be a n00b driver but thats the way I see it. I would love to have the power of a v8 without having to go forced induction, I don't have the knowledge or the deep pockets needed for doing it properly. I guess my car won't be a monster miata...
                                          A quick car? The MIATA? I think not. It IS a fun spirited car to drive because it is so light. But 300 ft lbs as you refer to it is only 300 ft lbs when you decide to use it. I'd rather have the option of having the power and deciding NOT to use than watching whomever go right by. I'm speaking from having one for almost 4 years now. You'll see when you get more wheel time. OF course you may be comparing it to previous cars you have owned. Then it may seem like a supercar. You can only justify the cars handling prowess and power to weight ratio so much.
