  3. Run Your Mouth
  4. Swap.........avi?
Swap.........avi?
80 Posts 15 Posters 9.3k Views
    one weekend = much more than a case of beer...
      LOL, zbrowns fab skills >you.
      quit posting in this thread already! You might realize that its sarcasm?? BTW, me and zac both have pretty much everything from our firewalls forward home made. I have a full engine swap, transmission swap, and a complete turbo system that is all fabbed. Plus i had to re-make about 3/4 of my engine harness and adapt it into the factory wiring. It is not hard, and it is painfully obvious that this kind of shit has to be done.
      Integrating a full EFI system from one car to another is so easy, i would even guess that you could do it. After cleaning out my harness of un-needed wiring and grouping like components, i only have 6 wires coming out of it. Constant 12+, Ign power, Crank 12+, fuel pump control, Serial data out, Tach signal. Thats it, OOOOOO it was sooooo hard!!!!
      Not joking, it could be done in a month, working weekends and an hour or 2 at night during the week, making the motor mounts is the easiest, and the engine/trans could be bolted in easily in 1 weekend.
      Gary
      • LupusSingularisL Offline
        LupusSingularis
        that was my point from the beginning, its not a weekend project... so far no one has fullfilled my request for links and parts and cost lists, or a realistic budget, which is what I think Kidsupreme was looking for in the first place besides genereal thoughts. All I've heard is just a "I can do it with some stuff that will probably work" reply.
        the fact that everything from your firewall foreward is homemade is quite impressive and comendable, and I respect your skillls for doing so. In fact I will say that you're skills are definately better than mine. But you still have failed to answer my questions and comments specificly and I would like to see a realistic timeframe and budget for this project.
        Every time that someone says "I don't believe in Ricers." Somewhere, there's a Ricer that drops to the ground, DEAD.
          when you decide to take on a project like this, that is somewhat breaking into new territory. You go in knowing its going to cost alot, take longer than expected, and involve alot of fabrication.
          Now the cost can vary so widely that shouldnt even be discussed in this thread. If you scrounge a motor for $50, or $500, waiting on ebay for deals on used haltecs, buying a new AEM, or going Megasquirt (the right choice BTW) can also vary from $400 or so up to $1500.
          Another thing to consider is how much can you do on your own. I could probably do 90% of the swap with a stick of flat iron, a shear and a welder, all of which i have. But the regular joe doesnt have shit for tools, that will change the cost immensely.
          This also affects timeframe. If you have all the above, and all the parts sitting there it could be done in a week or so. Otherwise it could take a year or 2 if your scrounging deals and stuff. I did mine over the course of a winter, and bought what i needed as i needed it. (This included removing the body and rebuilding suspension, all lines, etc.) The thing that actually took the longest was staring at wiring diagrams and waiting on parts.
          Gary
            man, we can tell that your a "bolt on guy".... of corse a swap this complicated cant be done in a weekend..... go "bolt on" some parts to your wicked street machine and go away.... if you dont know what you are talking about... stop posting KTHXBYE
              Quite frankly, doing the 2.3 engine swap is not necessary. For the fucking around involved vs the power output gained, Your better off turboing your existing setup. Price is going to be cheaper in the long run and no "real" fab is needed. Not to say that fabbing wouldn't be cool but as far as being original... It's already been done. Oh ,and power is comparable. The 2.3 head isn't the best at flow w/o some port work.
                oh i know..... i was thinking he should do that from the get go....
                • ErikE Offline
                  ErikE Offline
                  Erik
                  I dont' know what you're all talking about with turbo coupes and 8.8 ends and whatnot.
                  I'm pretty much sold on the rotary.
                  13B for life
                  They call me, old man...
                  • capitljC Offline
                    capitljC Offline
                    capitlj
                    He must not know how much we North Dakota Boys drink.
                    Its impossible to give you that information until someone actually does it. The deal is that if you can visiualize it, anything is possible. He obviously has a vision for this and using it I'm confident that he can get it done. You, however, I have no confidence in.
                    > Mitch Hedberg wrote:
                    2004 Impala LS 3.8
                      AMEN.........
                      thanks for posting gary, good post, really it was
                        13B for life
                        i have 2 for sale :rolleyes:
                          13B for life
                          :icon_cheers: :icon_cheers:
                            Awww c'mon. Swap an R26B in there. Make it a real swap.
                              hey parker, how much for those 2 13b's?? (4-rotor anyone? with a 91mm snail??)
                              Just curious, since i know how to do all the machining to make it work
                              Gary
                                ^^^ there ya go^^^ Exactly what I was talking about in my last post.
                                  200 each OBO.... and you help me take them out
                                  • capitljC Offline
                                    capitljC Offline
                                    capitlj
                                    $400, maybe I should put a quad rotor in the cougar. lol
                                    2004 Impala LS 3.8
                                      I think that he has a vision of some shit stirring
                                        Real men put a 351W into their cars
                                          real stupid men....
