  4. Displacement
Displacement
87 Posts 32 Posters 3.6k Views
  • ErikE Offline
    ErikE Offline
    Erik
    If there is no replacement for displacement, how do things like this happen:
    1988 Camaro RS. 5.0 L, 170 hp
    1989 CRX SiR - 1.6 L, 160 hp
    One year apart. 3.4 L. 10 hp.
    You're right. No replacement for displacement.
    And I would've gone further back in time but I had no resources for those old 1920's-30's v12's that made like 50 hp.
    They call me, old man...
    • kzriderK Offline
      kzriderK Offline
      kzrider
      1988 Camaro RS. V-8 5.0L (305CI) 4 Barrel Carb 170HP@4400 and 250Ft/lbs@2800
      1989 crx SiR - 112 @ 7100
      Wow only 1 year apart 3.4 L 138 Ft/lbs
      No replacement for displacement. and BTW, next time you make a comparison between two vehicles you could probably use the top package for BOTH vehicles. You chose the lowest 5.0l motor option that gm offered. Lets try this comparison again evenly.
      Low Package Comparison:
      1988 Camaro RS. 5.0 L, 170 hp 250 ft/lbs
      1989 crx sohc 8 valve - 62hp, 90ft/lbs
      High package comparison:
      1988 Camaro Z28 5.0L, 220hp 290 ft/lbs
      Displacement ftw, ....again :owned:
      Sinister Racing
      Free will, Free ride, Free style
      • ErikE Offline
        ErikE Offline
        Erik
        God that Camaro would be so good at towing my boat.
        The argument was, "no replacement for displacement"
        But reguardless of model trim, no one can deny there are replacements for displacements. Whether it be technology, forced induction, or nitrous. That's why they're popular and work in the real world.
        EDIT: found one:
        The original 448 in³ (7.3 L) Lincoln V12 was used in the large Model KB line for 1932 and 1933. It produced 150 hp (112 kW) and was an unusual 65° L-head design
        Mind Blowing.
        2ND EDIT:
        I bet someone responds to this with something about torque
          it made torque
          • G Offline
            G Offline
            GoldyHatchPSI
            Torque can lick balls.
              tqisking
              tq can get it done to.... you just do not have to spin it to the moon....
              I make peak power at 6200-6400 and peak tq at 4800-5100 640ftlbs....
              Car weighs 3600lbs and runs 9.75 @ 138 N/A
              You just have to gear the car correctly to use the power curve. 🙂
              • capitljC Offline
                capitljC Offline
                capitlj
                Torque moves cars horsepower sells them. Why exactly did engines from the 20's come up? I should damn well hope that a newer smaller engine makes as much, or more, horsepower. We have had over 100 years to develop the internal combustion engine, wheras they had <u>maybe</u> 30. If technology is the replacement for displacement then why are race teams, drag teams in particular, using massive V8 engines? With all the technology the top teams have access to why aren't they building small inline 4 motors, or even small V8 motors for that matter. The arguement that RPMs are a replacement can be made, i.e. indy cars, but what are you doing when you run an engine at higher RPM. Moving more air into and out of the engine, pretty my the same thing as using a bigger one in the first place. Except with a bigger one you don't have to put as much time into making it hold together so its cheaper.
                > Mitch Hedberg wrote:
                2004 Impala LS 3.8
                • XJHEADX Offline
                  XJHEADX Offline
                  Yep, torque really sucks
                    Why don't they use V12s or bigger if displacement is the best thing ever??? 8 cylinders is the magical number i guess??
                      8 cylinders is (generally) the largest practical motor you will fit in most engine bays....aside from that, it is readily available already so the whole concept doesn't need to be redesigned. Then there is the cost factor of a larger block, 33% more pistons, re-engineering the cams/crank/etc... Then, there are class restrictions and other obstacles when it comes to professional racing which can limit the displacement and/or the number of cylinders allowed.
                        yes HP is determined from TO and RPM............. but a car's acceleration G's is directly proportional to the HP curve .......... not the TO curve
                        • XJHEADX Offline
                          XJHEADX Offline
                          Wrong. A car will accelerate exactly matching its torque curve, not its horsepower curve. A car will accelerate hardest at its peak torque.
                          300 foot pounds of torque will accelerate you just as hard
                          at 2000 rpm as it would if you were making that torque at 4000 rpm in the
                          same gear, yet, per the formula, [HP= (Torque * RPM) /5252] the horsepower would be double at 4000 rpm.
                            you are correct accel. G's match the TO curve directly not the HP
                            horsepower is still the determining factor in the rate of acceleration of any vehicle though
                            http://www.yawpower.com/tqvshp.html
                            really good article, there was a second more in depth section but do you think i could find it
                            • capitljC Offline
                              capitljC Offline
                              capitlj
                              Chuck touched on this lightly but 8 <u>is</u> sort of a "magic" number. An 8 cylinder four stroke engine has two cylinders on the "power" stroke at any given time vs a 4 cylinder engine which only has one. Why is it you think a V12 ferrari with 500 hp feels different than a V8 ford with 500 hp. Its because the engine has three cylinders on the "power" stroke at any given time so its power delivery is smoother, although it does not have any more power than the V8 engine.
                              2004 Impala LS 3.8
                                OK, so what you are saying that more displacement isn't necessarily better?? OK, thank you very much.
                                  I'd rather have the non-smooth power delivery of a 500hp 4cyl...
                                    your a fucktard....
                                    • no_slow_clapN Offline
                                      no_slow_clap
                                      ^^^agreed.
                                      my honda was slow
                                      EVOLUTION VIII
                                        no_slow_clap;213570 wrote:
                                        ^^^agreed.
                                        my honda was slow
                                        lol..... funny
