  3. Run Your Mouth
  4. Tundra is weaksauce
Tundra is weaksauce
42 Posts 15 Posters 5.4k Views
    Wait, you abuse your trucks Parker?
    • 91nbtsi9 Offline
      91nbtsi9 Offline
      btleier;213220 wrote:
      thought you guys might get a kick out of this
      http://i26.tinypic.com/16kz3f6.jpg
      That's funny right there.
        lol.... no... i baby the shit out of it... i can hear my truck scream everytime i get close to it... "please god no... not again... please no!...."
          roffles
          Any luck finding reasonably priced "things"?
            MisterCMK;213280 wrote:
            roffles
            hell no... no nice ones for under 22k
            • G Offline
              G Offline
              GoldyHatchPSI
              RidinRails;213191 wrote:
              who gives a shit...
              Thank you
                These are some quotes from another site i frequent. Although i agree with alot of it, its just some more random info on how shitty the tundra really is:
                Toyota's Tundra marketing campaign has been relentless.
                Here are a few facts:
                Toyota has spent around a billion dollars in product design, plant tooling & construction and advertising promoting this turd.
                Facts:
                The "Tri-Tech" Frame. Was copied from Silverados from 1999. The front section isn't even as good as the old Silverado frame because it's not even Hydroformed. It's a boxed design but welded, then it is C channel to the rear.
                Big Brake Rotors. They talk about how big their rotors are, but if you check out the stopping distances between their "big rotor" Tundra and the Silverado, the stopping distances are the same from 60 mph to 0 and the Silverado has a 10ft shorter stopping distance from 70-0. The reason why? It's not about brake rotor diameter, it's about "swept area". In other words Silverado has a slightly smaller brake rotor, but their brake pad is larger so the clamping area is greater.
                381 Hp They used to advertise having the most powerful 1/2 ton truck. The reason you don't see any more ads is because the GMC has an available 403 hp. Their 381 hp engine peaks at 5600 rpm. Anyone drive around town a 5600 rpm? When I say "peak" I mean peak unlike GM engines which have a flat powerband. That's why they use a 4.36 gear to keep it in the powerband. They don't offer a different gear either. It also has probably the worst fuel economy of any 1/2 ton truck.
                6-Speed Automatic. Sounds great? One would think that a 6-Speed trans would give you better fuel economy. Sorry, the Tundra gets 2 mpg less than a comparable Chev with a 4-speed Automatic.
                Other misleading ads they've run. Ever see them pulling the weighted trailer up a ramp and hear them say "it takes a lot of power to move 10,000 lbs up this ramp and even better brakes to stop it? Well, Toyota was confronted about this ad and wouldn't deny that the truck wasn't pulling 10,000 lbs, but 10,000lbs was the combined weight of the truck and trailer. Plus they wouldn't deny that the trailer had electric brakes.
                They even use 5 lug wheels on this "truck that's changing it all".
                Toyota owners are complaining about their tailgates splitting apart. Toyota's response? They're telling people to remove the tailgate when loading heavy items in the bed.
                Toyota has acknowledged that they have a camshaft failure problem on the 381 hp Tundra. They are not going to recall them and have decided to repair them as they arrive in service departments.
                There's also a driveshaft problem and they're working on a fix.
                Recently, Toyota recalled another 200,000 vehicles. More than anyone in the industry. The media refuses to slather the number of recalls over the airways like they would if it were a GM or Ford. In my opinion, somebody is paying somebody off. Why else would the public not hear about this sham of a company?
                Now that we're done with that...I have done a lot of research on the LSD differential on the Toyotas. I've driven both trucks at a GM ride and drive event. This event wasn't skewed by GM. They had trucks from GM, Toyota, Ford, Dodge and Nissan. We had the opportunity to see for ourselves the differences between all of them....not by having a commercial give us misleading information..but by getting under the wheel and DRIVING each truck. The GM had the Eaton locking diff and the Toyota had the LSD. Since the LSD uses the brake system to try and apply traction, it overheated and shut down.
                  Facts:
                  Yet the Toyota front end doesn't seem to have any problems
                  This may be true, but are we comparing standard brakes (Toyota's are standard across the entire lineup) vs the bigger brake options of the Chevy? I don't know, it was your source so I am not looking it up.
                  But how about the 401 ft/lbs of torque? Apparently there is power down low somewhere
                  Had ZERO to do w/ fuel economy (IMHO) and more to do with towing...a side affect was that it gets better fuel economy due to more gears. What motor is the Chevy 4 speed mated to for this comparison? The 6.0 liter or a smaller motor?
                  Sounds like they've learned to copy more than just frame design from the big 3
                  I have no comment on this
                  If the tailgate is the only that ever breaks on a pickup hauling heavy loads, most would be happy
                  They have been recalled and replaced. It is no longer an issue and hasn't been since ~Sept 07
                  Link?
                  They also sell more cars than anyone in the industry. How major are the recalls? I don't know the answer...again, you cited it, you provide the source.
                  I can't speak to this either. I've yet to have that problem under normal driving conditions, so to me it is a non-issue.
                    How about we post up whats shitty about every vehicles on this site and how they compare to others!!
                      Well my Dads silverado tailgate broke when we were hauling carpet....so chevy is weak sauce also.
                      • XJHEADX Offline
                        XJHEADX Offline
                        http://www.youtube.com/profile_videos?user=CarDataVideo&search_query=ford+vs+toyota&search=Search
                          yet another good example of a "town truck"..
                            :fork: Chevys are weaksauce
                            • 91nbtsi9 Offline
                              91nbtsi9 Offline
                              The tailgate broke? Or did the cables break(which was a recall). Just curious..
                                Cable broke...shit I expect any truck to snap one with a housefull of carpet. That shit was heavy.
                                  the plastic around the cable would get holes in it and the cable would rust out.... hapened on our quad cab S10...
