  4. Car Problems
Car Problems
14 Posts 7 Posters 616 Views
  • DWeigsD Offline
    DWeigsD Offline
    DWeigs
    I do a lot of city driving and barely if any highway/interstate driving. Usually nothing over 40 mph. My car has been smoking a little more then usual of the exhaust lately like it has been either burning oil or running really rich. Last night i was out(tintmasters show and shine cruise) on the interstate a little bit along with getting on it more then i usually do. Now this morning when i went out and started it i noticed a more then usual amount of smoke(light blue to a darker blue) i noticed some black fluid, I then proceeded to rev it up a little bit. I then noticed something that didnt appear to be normal.(pictures below) Does anyone have an idea what could be causing this other then 178,000 miles. I am guessing a head gasket.
    Thanks in advance!!
      valve seals or pistons rings.
      HG isn't going to cause oil in the exhaust.
        Get a compression test to see if its ur rings...
        • BookemB Offline
          BookemB Offline
          Bookem
          Which will make it smoke more, when you first start it up, more when the engine is not warm, idling or when you are giving it throttle?
          Legacy GT
          Gmc Suburban
          Hallorann: Fargostreet?
          Hallorann: No, I ain't.
          • DWeigsD Offline
            DWeigsD Offline
            DWeigs
            When I first start it up either in the morning or when i havent drove it for a while it will smoke quite a bit. It doesnt smoke to bad terribly bad when im just driving but if i get on it then i can see a lot of smoke in the mirror.
            • BookemB Offline
              BookemB Offline
              Bookem
              Valve seals, probably rings too.
              Legacy GT
              Gmc Suburban
              • DWeigsD Offline
                DWeigsD Offline
                DWeigs
                I dont think its oil thats coming out of the exhaust... It feels like its just like a chalky substance, like carbon or something mixed with some kind of fluid. It doesnt smell like oil.
                  are you sure you aren't losing coolant??
                    Just buy my ls/vtec and make it go fast, lol...
                    • DWeigsD Offline
                      DWeigsD Offline
                      DWeigs
                      Its tempting...
                      As for the coolant, I did just go check to see because someone else mentioned that. It is lower on coolant. It was just full about a week or so ago because I had my oil changed.
                        DWeigs;214497 wrote:
                        Its tempting...
                        Well if ur interested i'll make u a good deal... I have ecu and mounts... all u'd need is a trans and some axles...
                        • CRX_CivicC Offline
                          CRX_CivicC Offline
                          CRX_Civic
                          :icon_puke_r:
                          • DWeigsD Offline
                            DWeigsD Offline
                            DWeigs
                            CRX_Civic;214661 wrote:
                            :icon_puke_r:
                            Does this mean something?
                            • capitljC Offline
                              capitljC Offline
                              capitlj
                              If its coolant you shouldn't see blue smoke and your exhaust would smell sweet. Blue smoke is oil, and the fact that its bad at startup makes me think valve seals.
                              > Mitch Hedberg wrote:
                              2004 Impala LS 3.8
