  4. Headlight scratches
Headlight scratches
3 Posts 3 Posters 808 Views
  • GarageAlchemistG Offline
    GarageAlchemist
    My 94 sho prolly has the origional headlights on it and i could car less, but the front of them are all chipped up by rocks and such. I don't really want to buy new ones, but is there any way to get rid of the scratches?
    97 GTi, 03 KJ
    • -GSX-Falcon- Offline
      -GSX-Falcon
      You could try some wet sanding with some fine sandpaper and finish it off with some rubbing compoud and see what that does. I had some minor dings in my lights and that helped alot. Not too sure how much it would help larger chips.
      92 GSX Automatic -Manual Cams, Injectors, ECU -Big 16g -Turboback Exh -Ported Evo Manifold -Ported 2g o2 -MBC -JDM 4g63 -Walbro 190 -3" Intake
      • M Offline
        M Offline
        mym6
        If they are plastic try to find some plastic polish to finish up after the rubbing compound. I would think most rubbing compounds would be too abrasive not to follow up with something else.
