  4. Lexus Engine + Hose Water = Bad Misfire...
15 Posts 8 Posters 821 Views
    I'm sure nothing is fried. It took my Supra a trip to DL and back to basically start running perfect after drying out overnight lol. I didn't remove the valve cover/Intake manifold, but made a vacuum attachment to grab most of the water out of it lol. If you haven't found out yet, there is a huge valley there for water to sit, especially in the plug holes. If it runs enough the water should evaporate, otherwise leave it taken apart overnight and it should be a bit better in the morning lol. Good times huh?
      hot nasty rippers up and down the interstate to grandforks, fix dat shit son. forget to cover the distributor did ya?
        When I had that car detailed the same thing happened, but they just dried everything out by using compressed air, then all was good.
          take off your cap and hit with light blasts of compressed air. dry off any electronics under the hood.
          • StangerBanger96S Offline
            StangerBanger96
            I am replacing the plugs too...the ones that were in there were single ground and the owners manual calls for ONLY double grounded. Plus they looked kinda dirty so I figured some maintenance would be good for it!
              So, your spark plugs looked dirty?
                shoulda washed those as well
                  StangerBanger96
                  Yeah it was the plugs from what I can tell...no issues after I replaced those. Toyota sure screwed up on that engine design I think...that's way too much "work" just to change plugs!
                    LOL Yeah exactly.
                      you need one of my intake manifolds. 🙂 then it takes 1.382 minutes to change all plugs.
                        StangerBanger96
                        Is this intake manifold you're talking about one that includes/goes with one of those snail type contraptions?
                          Yes, your car would be much happier with one of those snail thingies also.
                            StangerBanger96
                            My car yes, me yes, my transmission no, my wallet definitely no 🙂 I wish!
                            • Afsil80A Offline
                              Afsil80A Offline
                              Afsil80
                              But your car would love you forever.
                              -Peter
                              1991 240SX
