  4. wet sd harvest (stuck combine)
58 Posts 16 Posters 5.2k Views
  • beachbum_jonB Offline
    beachbum_jon
    because there is no place to hook on to. you cant pull from the rear axle on these combines, they are to heavy and the the only only spot to hook onto is the tow hooks underneath the front axle and if you put a cable onto that and pull backwards, the cable with press up against the augers and other components underneath the belly of the combine. we did think about pulling from the rear axle but we called butler cat and asked them how much damage can the combine sustain if you rip the rear axle off. and they said they've seen 40k in damages from doing that.
    -John Adams, 1735-1826-
      we have no problem pulling ours out backwards.... i cant imagine it would be easy to rip the rear axle off
        beachbum_jon
        what combine do you have?...if you look at the back of the cats, the only point where the axle connects to the rest of the combine is the pivot point. thats it. and if you start knocking around to where that pivot point is welded to the rest of the combine you can easily see why....not a good place to pull from
        • dubbsyD Offline
          dubbsyD Offline
          what incompetent engineer decided it would be a good idea to design a combine that did not have a solid pull point to the rear?
          Oh, I know. The same moron engineers that make half of the parts on equipment nearly impossible to replace. Sure it's easy to get to on the computer you idiots...
          • khock3K Offline
            khock3K Offline
            khock3
            we anticipated getting stuck so we put cables on our combines so it would pull from the front axles. also on the way home, some mud that was stuck in between the duels flew off and broke the ladder on one of our combines.
              beachbum_jon
              we this combine is a little different, most of these combines were ordered with duals, and they an extra cross member on the front axle for the spacers of the duals. and that cross member had a point that you could pull from. but for some odd reason this combine was ordered with big singles and doesnt have that cross member to pull from. after this little incident we are going to be fabricating a bracket that bolts on to the front axle so we have the option to pull from the rear, beings that we will be getting stuck alot more this year
                at the moment two 470's. but looks like we might be getting the two 595's sitting at butler...
                  [borat]Very nice![/borat]
                    beachbum_jon
                    why? 595 is a big combine, and tracks are a little of a over kill. why the big jump from the 470 to the 595?
                      because we have more land.... and we want to get things done faster.... 🙂
                          beachbum_jon
                          ha okay that makes sense. next year we are getting a 580r, we have no need for tracks as they are a 70k option and for 70k we are more than willing to pull it out with our cat challenger that we already have, or if need be our neighbors excavator.
                          btw the way how many acres you guys farm?
                          • z31Z Offline
                            z31Z Offline
                            z31
                            Hey guys, real combines are green.
                            • dubbsyD Offline
                              dubbsyD Offline
                              holy fuck...
                              what are you running for tires on that? wide single + addon dual?, metric duals?
                              Saw guys running the former one year out in my area with some wet ground.
                              • dubbsyD Offline
                                dubbsyD Offline
                                sandy down there?
                                A combine that damned big should be on tracks to prevent compaction.
                                  weaksauce...
                                    beachbum_jon
                                    Parker;243214 wrote:
                                    weaksauce...
                                    cat pawns all...
                                    dubbsy: yeah its pretty sandy around here, but as far as compaction goes, duals or big metrics are just fine, tracks are mainly for very soft conditions, now if you go 590 you might as well step it up and go 595 to get tracks, 590's are a whole nother machine in its self, can you say class 9 combine, the only class 9 combine
                                      what the fuck are you smoking??
                                      The NH CR9080 and IH 9120 are both class IX machines.....:icon_scratch:
                                      Even though the class system is a joke...... all it measures is the through-put capacity without stalling, not about the job being done, or lack of.......
                                      you could give a POS JD 9600 700 hp and have a class IX machine
                                      you can go ahead and have your Claas machine.........:icon_puke_l:
                                      and i will stick with my superior NH
                                      Thanks for posting those pics Jason (z31).... I was thinking weaksause when i saw the original post.....Its not extreme harvesting until you are steering with your brakes
                                      It looks like to me the operator sank...... and spun like a retard and buried the front left..... since he/she didn't have RWA
                                        dubbsy;243209 wrote:
                                        holy fuck...
                                        ha...
                                        they actually took the duals off the largest machine and and swapped on 1200's................huge.....
                                        I don't care who you are, without RWA those machines are going nowhere in that stuff........ never been around tracks minus RWA to know what that would be like
                                          superior... lmfao....:icon_salut:
