  4. just curious about hp...
64 Posts 18 Posters 8.9k Views
  • slow90gsxS Offline
    slow90gsxS Offline
    slow90gsx
    https://secure.buschurracing.com/catalog/product_info.php?cPath=22_38&products_id=434&osCsid=93cf107efb8002a8df95aecaf5226c5c
    We went to buschur and bought the car from a guy that worked there this is the one^^^
      blackcherryTSi;244000 wrote:
      20g for 350... may do it... undecided.... also had a question.. anybody have a jdm dash peice where the cup holders are? kinda vauge but it turns that into just a pocket
      http://passwordjdm.com/EG-92-95-Civic-HOP-Optional-Center-Console-P2359C138.aspx
        SPANISH-RICE;243981 wrote:
        whats wrong with a turbo fwd car for what he wants? Traction problems? Almost any other application is just going to run into diff problems and costly clutch swaps with that power to get even close to what hes looking for.
        Please elaborate???..... all knowing one
        SPANISH-RICE;243900 wrote:
        Woaaa dont get all defensive the only reason why you are involved at all with anything i said was becuase i fucking agreed with you. I was saying that for other people like travis who seemed confused by the idea of someone using a 50 trim and making more power than 270hp.
        But im glad that you also know what i know, and that you feel the need to throw around dimensions and basic math i already knew about your useless fucking turbo. Any one can use google and tell you your in./ex. Diameters, congrats
        stop trying to sound so smart by telling people the small about about basic shit that you know
        You were calling me out, insinuating I was using trim to differentiate the size of turbos...... as bigger or smaller
        I only clearly pointed out that different turbos use different characteristics to name them........... and that in this case it was trim that was used
        Obviously I looked up the wheel specs of both to illustrate my point....
        Since you are so well endowed with the understanding of turbo dynamics will you please help me size the optimum turbo for my setup???........ please master
        • 9 Offline
          9 Offline
          91psiTSI
          200hp on 10 psi
          • speed_ricer69S Offline
            speed_ricer69
            hey talk to lil mikey
            The Hanson's were the first to invent v-tec. MMM BOOP
              the 20g will not be good for his setup right now as i beleave it has a tdo6 compressor wheel and housing? correct me if i'm wrong zac. 1 full size up from the 14b which uses the tdo5 housing, that with the 1 step up turbine wheel and a 10cm turbine housing vs the normal 6 or 7cm turbine housing would slow spool-up, conciderabley.
              again with a built bottom end he is capable of running higher boost to compensate for the low compression.
              so i don't see how this is a bad set up. he has room to upgrade and it will be plenty fun at the 200-240 whp range with a nice torque curve.
                Are you being very sarcastic??... or serious??
                  very serious, why?
                    DrifterExtreme;244088 wrote:
                    very serious, why?
                    super
                    • gsrEKG Offline
                      gsrEKG Offline
                      gsrEK
                      um who cares? run a gt40r then u will have 301 hp haha
                      2009 Yamaha Zuma 125, gas HOG
                      2008 Honda Fit daily
                      A s2k
                      1991 Honda civic DX Mint SOLD
                      1988 Mitsubishi Mighty max
                      > BlackEJ8;233529 wrote:
                        I would just put "10s next spring" in my sig and call it good.
                        • no_slow_clapN Offline
                          no_slow_clap
                          same thing as the fp green. good for making 400w at 28 psi..
                          EVOLUTION VIII
                            zbrown;244032 wrote:
                            you were calling me out, insinuating i was using trim to differentiate the size of turbos...... As bigger or smaller
                            i only clearly pointed out that different turbos use different characteristics to name them........... And that in this case it was trim that was used
                            obviously i looked up the wheel specs of both to illustrate my point....
                            Since you are so well endowed with the understanding of turbo dynamics will you please help me size the optimum turbo for my setup???........ Please master
                            at no point did i call you out, in fact i dont even acknowledge you on this website. Its you that assumes everyone is calling you out because you think you know everything.
                            I made a comment on what trim is because a previous comment was made
                            gsrek;243877 wrote:
                            true. I maxed my 50 trim out at 270 whp on a mustang dyno at 18 psi. I wish i woulda got a bigger turbo also.
                            and i did not want certain people to think that just because they have a "50 trim" they are gonna max out their turbo at 300 hp. See how that makes sense?
                            Reread the shit that was said before even trying to throw your opinion around again becuase all it does is make you sound like a douche with "something to prove" to the online community.
