  4. Meth Injection Q's
Meth Injection Q's
30 Posts 15 Posters 876 Views
    aww i was hoping you would go with the JRSC Miata autoX Madness Machine, bu boost on it will be sweet. That for the winter project?
      I would run both. Run an intercooler with some meth. its safer
        Talk to Jason (Z31) about it. He's running it on the Z he has. But I think he's switching to a FMIC. It may be initially easier to do but it's kind of a pita to have to rely on it all the time. Kinda like nitrous.
          Meth has too many variables and is too risky IMO to rely on rather than using an intercooler.
          • z31Z Offline
            z31Z Offline
            z31
            http://www.alkycontrol.com/
            http://www.turbobuicks.com/forums/alcohol-propane-nitrous/
              I would do the intercooler until you get to the point of having to add meth. I did it this way, turns out to be a shitload of work when your spraying meth at every single stoplight. I love the stuff, but i would like to have an IC first, then meth for huge power on pump, prefferably set on a 2-stage boost controller.
                intercooler plus http://www.snowperformance.net/
                • SlowicaS Offline
                  SlowicaS Offline
                  Slowica
                  i would also just go with the intercooler you can find them for pretty cheap if you take the time to look
                  • no_slow_clapN Offline
                    no_slow_clap
                    why wouldnt you want an intercooler?
                    you can add to the rice, its safer, and you dont need meth.
                    i thought meth was used more as an additive, not a cooling system.
                    EVOLUTION VIII
                      no_slow_clap
                      find a used evo intercooler, i would give you mine..but it cracked.
                      its inexpensive, and it works.
                      EVOLUTION VIII
                      • StangerBanger96S Offline
                        StangerBanger96
                            Injection >>> Intercooler
                            I'd like to see you get well below ambient IAT's with your A2A IC.........
                            while having better boost response and a simpler system, without tearing up your front.....
                            There is an awesome thread I should link to on the club..........
                            showed a ton of well documented logs (IAT's ect) going from a large FMIC to strictly chemical inection........ showing the results of different mixtures of water and alcohol on IAT's
                            great results
                            There is no way i am going to run an IC on my car
                            not saying A2A IC's are bad or anything, they are a good thing, just not required with a good injection system
                              I agree the injection system is just one more thing to worry about, but it does have definite advantages
                              and i for one hate intake piping going all over
                              • z31Z Offline
                                z31Z Offline
                                z31
                                Wes, I'm going with Nistune tuning software, E85+Methanol injection, and 9:1 compression pistons for now.
                                Like Zack said your Intake Air Temps are going to be below your outside air temp and you can go 30% over your fuel injectors for extra fueling. I think the octane rating is 112
                                  Why not use an intercooler along with meth injection?
                                    no_slow_clap
                                    agreed.
                                    EVOLUTION VIII
                                      no_slow_clap;245969 wrote:
                                      agreed.
                                      because joel just said he didn't want to fit an IC........
                                      and AI alone has some advantages over running both together
                                      there are some hardcore fanatics of AI in the rotary world....with unbelievable results
                                      for instance, on your typical 13b setup with pump gas alone, you are looking at around 15-17psi being your safe ceiling................with a good injection system people are around the area of 25psi on pump gas alone.....all day, every day
                                        no_slow_clap
                                        I understand the advantages, but why would you want to substitute cooling for an aditive?
                                        Joel, your car is going to be down all winter, its not like you wont have time to make something work. you can make your piping...the way you want it, and an ic isnt that expensive. you can buy a good used one one ebay for cheap.
                                        not only that you dont have to worry about proper applications for your car, you can buy a used side mount and make it work.
                                        EVOLUTION VIII
                                          haha i love these threads, everyone is so afraid of meth injection.
