  4. Bored so here are some pics of the new Aidsmobile.
93 Posts 27 Posters 5.9k Views
  • ihaveaidsI Offline
    ihaveaidsI Offline
    ihaveaids
    Ah never mind I remember that now, you and your bright ass hids.
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      u must be slippin in age huh
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
        ihaveaidsI Offline
        ihaveaids
        Damn, I guess.
        • SlowicaS Offline
          SlowicaS Offline
          Slowica
          clean car and +1 to getting the wheels powder coated.
          • GhettoFabulousCRXG Offline
            GhettoFabulousCRX
              ihaveaidsI Offline
              ihaveaids
              Thanks.
              • sitn2loS Offline
                sitn2loS Offline
                sitn2lo
                            ihaveaidsI Offline
                            ihaveaids
                                    Nice looking car, reminds me of one of my friends cars, till it got hit twice....but the Works look kinda stupid on it imo.
                                      • Gundar1G Offline
                                        Gundar1G Offline
                                        Gundar1
                                          ihaveaidsI Offline
                                          ihaveaids
                                          Teh mod list for more hate.
                                          EXTERIOR
SiR Bumpers (OEM)
SiR Lip (OEM)
SiR Headlights with City Lights (OEM)
CTR Thin Side Moldings (OEM)
CTR Folding Mirrors (OEM)
CTR Front Grill (OEM)
99-00 AND 96-98 Tails
Antenna block off plate (OEM)
                                          INTERIOR
POR15'd The Floor/Trunk
Rest Is Painted Battleship Grey
Sound Deadening material is removed
Personal Neo Grinta 350mm
MOMO Steering Wheel Hub
MOMO-To-Nardi Hub Adaptor
Stock EK seats.
Buddy Club Quick Shifter
Buddy Club Shift Knob
Radio Block Off (OEM)
Master Kill Switch/Key
Carbon Kevlar Fuel Pump Cover
EX model Amber cluster with the original DX speedo swapped over to keep mileage
Amber climate control as well; matches the cluster perfectly(both use the same bulbs)
Mild rear wiretuck
Removed SRS system (everything)
                                          ENGINE
Tanabe Stainless B-Pipe
Spoon Sports Axle Back
Cusco Exhaust Hanger Bushings
Avid Racing Hard Billet Torque Mounts
Stainless Steel Clutch Line
Project Kics Magnetic Oil Drain Bolt
Clutch and Brake Fluid Bled (Motul)
Re-grounded with 6G Wire
Relocated Fuse Box (Under Glovebox)
Mild Wire Tuck (Headlight Harness, Grounds, Brackets Removed)
Swapped out the DX header for an EX
Brand new battery and starter and new ground wires installed at the same time
                                          SUSPENSION
Buddy Club N+ Adjustable Coilovers (re-valved to fixed rate/non adjustable)
Function7 Rear LCA's
ASR Rear Tie Bar (Polished)
ASR Rear 22mm Swaybar
Function7 Endlinks
Mugen Rear Trailing Arm Bushings
SRR Camber Arms
SRR Toe Adjuster Arms
Civic HX Front 22mm Sway Bar
Civic HX Front LCA's
Replaced BOTH tierod ends
