  4. Bored so here are some pics of the new Aidsmobile.
93 Posts 27 Posters 5.9k Views
  • ihaveaidsI Offline
    ihaveaidsI Offline
    ihaveaids
    Teh mod list for more hate.
    EXTERIOR
SiR Bumpers (OEM)
SiR Lip (OEM)
SiR Headlights with City Lights (OEM)
CTR Thin Side Moldings (OEM)
CTR Folding Mirrors (OEM)
CTR Front Grill (OEM)
99-00 AND 96-98 Tails
Antenna block off plate (OEM)
    INTERIOR
POR15'd The Floor/Trunk
Rest Is Painted Battleship Grey
Sound Deadening material is removed
Personal Neo Grinta 350mm
MOMO Steering Wheel Hub
MOMO-To-Nardi Hub Adaptor
Stock EK seats.
Buddy Club Quick Shifter
Buddy Club Shift Knob
Radio Block Off (OEM)
Master Kill Switch/Key
Carbon Kevlar Fuel Pump Cover
EX model Amber cluster with the original DX speedo swapped over to keep mileage
Amber climate control as well; matches the cluster perfectly(both use the same bulbs)
Mild rear wiretuck
Removed SRS system (everything)
    ENGINE
Tanabe Stainless B-Pipe
Spoon Sports Axle Back
Cusco Exhaust Hanger Bushings
Avid Racing Hard Billet Torque Mounts
Stainless Steel Clutch Line
Project Kics Magnetic Oil Drain Bolt
Clutch and Brake Fluid Bled (Motul)
Re-grounded with 6G Wire
Relocated Fuse Box (Under Glovebox)
Mild Wire Tuck (Headlight Harness, Grounds, Brackets Removed)
Swapped out the DX header for an EX
Brand new battery and starter and new ground wires installed at the same time
    SUSPENSION
Buddy Club N+ Adjustable Coilovers (re-valved to fixed rate/non adjustable)
Function7 Rear LCA's
ASR Rear Tie Bar (Polished)
ASR Rear 22mm Swaybar
Function7 Endlinks
Mugen Rear Trailing Arm Bushings
SRR Camber Arms
SRR Toe Adjuster Arms
Civic HX Front 22mm Sway Bar
Civic HX Front LCA's
Replaced BOTH tierod ends
    • smtomps1955S Offline
      smtomps1955
      there is no more room to hate. that battleship gray looks sweet!
      2003 f150 supercrew
      2002 Urabus WRX sedan
      1991 Nissan Hardbody
      :icon_puke_l:
        love the SiR bumpers... bout time someone rocks them... IMO ctr headlights would look way better... sell the work's on H-T and buy a black set or other set for much cheaper that way u got some extra cash... are the SW388s for sale (if they in fact are real)?
        • Gundar1G Offline
          Gundar1G Offline
          Gundar1
          Thats what I tell him too, ctr headlights are the shit.
          EVO
            ihaveaidsI Offline
            ihaveaids
            Ctr headlights aren't that great IMO. I think the previous owner already had the Spoons sold before I picked the car up, and yes they were real. If anyone is actually interested in the works I MIGHT consider it.
                ihaveaidsI Offline
                ihaveaids
                There are two stock Ex seats in it now.
                  now you can pick up chics
                    it's a hell of a lot better all clear lensed with them than the gay ribbed look on all other ek headlights... imo at least...
                          ihaveaidsI Offline
                          ihaveaids
                          The SiR aren't really my favorite either, I really prefer the 99-00 front end over all other ek fronts.
                            so where did you buy your car from?
                              ihaveaidsI Offline
                              ihaveaids
                              Illinois
                                • no_slow_clapN Offline
                                  no_slow_clap
                                    ihaveaidsI Offline
                                    ihaveaids
                                    Haha I would never sell works and buy slips.
                                      I would....
                                        http://www.fargostreet.com/forums/showthread.php?t=1170
                                        Just in case anyone forgot to read the actual rules of this area of the forum, I posted them right here for you all to enjoy. And this goes all the way back to 2004.
                                        BTW, I like the car either way. No matter the wheels. I can appreciate them both.
                                          So... would u ever get rid of the SiR conversion (bumpers and stuff)?
