  4. anyone know this guy?
18 Posts 6 Posters 778 Views
    squawsnatch
      squawsnatch
      KA-T_240;265135 wrote:
      IMO 16.5k is way to high for that PICKUP.
      fixed
      agree should be able to find one for around 10-12k
        squawsnatch;265255 wrote:
        fixed
        and again.. find one just as nice for cheaper....
          unless you are pulling 24/7 wtf would you want a manual??
          manuals suck for any fun in a cummins period......by the time you are into good boost you need to shift, and even worse with a larger than stock turbo
          unless you only like 5th/6th gear rolls....
          good converter + good auto >>> manual............ in a cummins
            What he said!!!!!
            • beachbum_jonB Offline
              beachbum_jon
              i donno, my buddie down here has a 01 with a manual and its a blast driving it, he has a monster pump, quadzillia with the pulse, intake, 4in straight piped, and a ceramic clutch (switching to twin disc). hes running 14.3 in the 1/4.
              i am thinking about putting a sun coast kit in an auto if i do go that route at school in my tranny class. but i sort of want to get into sled pulling down the road a little bit so the manual will be better for that.
              and if you think you can find a nicer one for cheaper, then show me, most cummins of that year have 200k miles on them, yeah the motor will last forever, but the rest of the truck wont, i dont want to have to replace the suspension right away, i dont want to have to replace or build the tranny right away, even though it will happen sooner or later.
              -John Adams, 1735-1826-
                so it would be in the easy 13's on a auto your saying?? I have ridden in decently fueled stick and auto trucks...........no comparison
                holding full boost and fuel through the shifts and being able to build however much boost from a stop is huge
                granted stock converters suck huge donkey dick because they are so loose that the truck doesn't go anywhere and the lockup clutch wont hold much abuse
                You would not even think it is the same truck just going from a stock converter to a good aftermarket, tight, multi-disk converter......and being able to do WOT shifts all the while the converter can hold locked, and the truck actually goes somewhere during just unlocked fluid coupling too
                there are some really good aftermarket converter/tranny stuff out there for the dodge/cummins stuff........like my converter is a Goerend, billet 3 disk...... guaranteed to hold 2000ft/lbs locked and an unlimited lifetime warranty ( i could break an input shaft and shred the convereter and it would be repaired for shipping costs only)..........
                edit, and should add not much more $$ than a really good clutch
                sorry for the rant, i just think you should get an auto 😉
                  beachbum_jon
                  thanks for the info, yeah i am really considering an auto, and actually i did find a truck in vegas that i might be going to pick up this weekend. its got about the same miles, short box, some supporting mods like a fass and gauges and some small stuff for about the same money. this truck is auto so i if i get it i will put in a lockout switch in it until i get parts from suncoast so i can build it in auto trannys class.
                  brown-what tranny you got, stock with goerend converter? i was thinking about doing a goerend tranny kit but they are sure expensive.
                    beachbum_jon;265522 wrote:
                    some supporting mods like a fass a.
                    good, should be the first mod on every 24 valve
                    IMO doesn't matter who you go with........ ATS, BD, Suncoast, and Goerend all have good stuff.... I just went with Goerend because from what i have read he stands behind his stuff 100% and his warrantys are usually better...... I can vouche he is awesome for customer service, which is hard to come by these days if you ask me
                    Yeah and I dont know the story on my tranny and I dont care if it never shits, haha
                    I bought the truck with 135k.... now has 206k............ beat the piss out of it with decent fuel and it holds like a champ still. ( i even dumped ALL the fluid out hauling ass to a fire when I blew a cooler line and it is still 100% somehow)...... So i am guessing it is not the original tranny becasue you know as well as me about these stock trannys, but maybe it is...... But yeah i have expected it to die for along time and never does, will stick with goerend when it is time though
                    A good auto setup WILL be more $$ than a strong enough g56 manual, but i feel well worth it considering the ton of good hard parts for these auto trannys anymore, and the big benifits it gives you on the cummins
                    good luck
                      squawsnatch
                      finally admitting that it has a suncoast?????
