Test N Tune Roll Call
HandoEX;273807 wrote:
Possibly if I get a new clutch put in. What is the cost to run again?Get to it already...
maybe I should - could be a nice cool weekend.
I'll be considering it. If its an all T&T weekend I may end up going out Sunday if I decide to work Saturday.
63vette;273840 wrote:
New website says $60. I hope that is wrong.I see $40.
http://www.interstatedragways.net/WHATS_NEW.html
(underneath the scrolling "Friday Test N Tunes") -
DaveH;275003 wrote:
How was test n tune on Sat? heard they didn't get started until after lunch?We got Matts car ready yesterday, but when we fired it up cyl #6 started filling with coolant.
So, we wont be out there today.It was kind of a disaster, they didn't get started until 12:30-1 as the timing system wasn't working. Then the first part opf the day the timing boards weren't working. Then they went to 1/8th miles for about an hour as that was the only system working and they had the boards working for that, then probably around 4 they got everything working and wernt back to 1/4 mile and the boards and timing system were back up.
FYI the new tech is on point about everything being to spec and legit, no more ok your good and no more running under ET w/o cages and safety equipment.
PSI2HI;275040 wrote:
FYI the new tech is on point about everything being to spec and legit, no more ok your good and no more running under ET w/o cages and safety equipment.^^^^^TRUTH. The Mustang a few pit spots down got the boot for running under their acceptable ET.
It was kind of a disaster, they didn't get started until 12:30-1 as the timing system wasn't working. Then the first part opf the day the timing boards weren't working. Then they went to 1/8th miles for about an hour as that was the only system working and they had the boards working for that, then probably around 4 they got everything working and wernt back to 1/4 mile and the boards and timing system were back up.FYI the new tech is on point about everything being to spec and legit, no more ok your good and no more running under ET w/o cages and safety equipment.
Any Idea if this will be strictyle inforced during the Tintmasters events?
