  4. New for 2009 Crx build thread!
88 Posts 23 Posters 7.5k Views
    Bryce;275319 wrote:
    Big thanks to Matt, Will, and Brandon for the help last night!
    Not a problem, was a good time. Let me know if there is more ya need done.
      anytime man! always a good time, even though i showed up a little late
      • no_slow_clapN Offline
        no_slow_clap
        Looks good.
        Rocking the KDW's?
        EVOLUTION VIII
          (These updates are made for a diff forum so that is why names, and small forum info is left out of this update)
          I'm sick of breaking/bending clutch petals so the crx is getting swapped to hydro.
          I picked up a mint LS tranny, ACT hyper light weight flywheel, and a ACT 6 puck clutch, along with a Hasport hydro conversion kit. I'll stick that in next week.
          Here are a few updated pictures from today! Still have not got my front bumper back from paint:P Don't mind the rusty brake rotors, I'm getting extended lug studs and brembos soon.
          I started getting the new plastics I ordered, so I installed these two yesterday. One of the old ones was held on by a wood screw. It always really bothered me.
          I got my hydro tranny, ACT clutch, ACT hyperlight flywheel, and hydro EF mounts today.
          After a good pressure wash (Thanks Josh!) I started giving it a much needed cleaning.
          Before:
          A preview of after. (I'm not done yet:P)
          Today I took the crx over to MGD fab to hang out with Matt, and to see what he was working on. I also started to install all my new hardware that I got for the engine bay, and motor.
          I love working for Honda and getting parts at cost!:D
          Then Travis stopped by with his 365hp D16z6 powered Civic. MGD fab built mani, down pipe, and dump tube. Looks sick!
          Matt was also working on a H22 mani for a MnHondas member.
          Then later I got around to getting the engine bay stripped and ready for paint.
          Thats all for today folks!
          • fdfreakF Offline
            fdfreakF Offline
            fdfreak
            looks good.
            12.645@118mph 12.6psi
            • fdfreakF Offline
              fdfreakF Offline
              fdfreak
              did travis install a bigger turbo?
                Yes he did.
                  so... u dont need my mounts??
                    its kinda wierd that bryces projects get done faster than yours?
                    :icon_joker:
                      Yes I do.
                      I also need D EG mounts, anyone have a set?
                        :icon_joker:
                        ya... must be nice to have your car like 10ft from where u live... lol
                          Yesterday I started on the LS/VTEC motor build for next season. I had a very clean rebuilt LS sitting around for a while, so time to get to work.
                          Took off the oil pan;
                          Then the oil pickup and windage tray;
                          Look how clean this motor is!
                          Pistons out (New LS pistons for sale BTW)
                          It has a fresh hone, and been hot tanked so that will save time and money.
                          Next I want to get a new crank, I'm thinking GSR, ITR, or CTR instead of the LS crank. They are zero balanced to higher RPM's then LS cranks. also a ITR oil pump, the move more oil then LS pumps. I have not decided on what piston rod combo to go with yet either. I have a oil cooler for it too.
                          The Ground Controls are set up and ready to go. My Koni yellows should be here any day now.
                          Thats all for today!
                            all new b series pumps are the same.
                            also ls crank will be just fine for anything you will do bryce.
                              Is the key word "new" oil pump? In the past when I read about lsvtec builds they always would run ITR oil pumps because they pumped more oil.
                              That is true on the crank, it will be boosted so I doubt I will rev past 8,ooo rpm.
                                What does being boosted have to do with only revving to 8k?? Boost means you can actually make power up there, might as well go to 8.7-9k depending on the head...
                                  bryce i think any pump newer then like 96 is the same as the itr pumps. the itr pump is just the revised version of the b series pump.
                                  but if your doubting yours pull it apart and check for wear if there is none you should be fine to run that one.
                                  Oh and trevor i think his power band will drop before 8500 so if it drops at say 8k there is no point to rev higher other then a gearing issue.
                                  but i'm preaching to the wrong person... haha
                                    Good to know, thanks Matt.
                                    What I have read is that Honda balances their crank shafts 1,ooo rpm past that motors rev line. That is why people put AP1 cranks that are balanced to 10,ooo in their K series. The rev limiter is 7k on a LS so I figured anything past 8k would be unsafe with that crank. It will be a stock B16 head, and IM.
                                    If I'm wrong, I'm wrong, but thats where I got my reasoning.
                                      what's on it for suspension at the moment?
                                        Yea, it will obviously depend on the turbo/cams/IM/etc, but assuming he stays stock B16 head and not too big of a turbo, it will drop off early enough.
