  3. Wanted Ads
  4. WTB: MAP Sensor
WTB: MAP Sensor
5 Posts 3 Posters 270 Views
    Does anyone have a MAP sensor off a z6? Needz ones asap, donka.
      All the obd-1 and 2 hondas are the same, just so you know it doesn't have to be off a Z6, i might have one but im not sure.
        Yeah i know, just figured it would make it easier if someone had one laying around and not sure if it would be the same.
        Not sure if I need a new one or not, got the ECU fixed and it ran perfect, then randomly when into limp mode, pulled the power, disconnected the O2 and it worked all night. So who knows, figured I would change mine out anyways just to be safe.
          go to napa and get a gm 3 bar and tune with that. youll be happier in the long run man. otherwise i have a map off a b16
            Brandon, shot ya a text idk if ya got it...anyways give me a call when you gotz timez. Ill take that MAP off your hands...see if that maybe fixes my problem.
