  4. belt squeal?
belt squeal?
24 Posts 12 Posters 1.8k Views
  • TsiTomT Offline
    TsiTomT Offline
    TsiTom
    i did buy a new belt though...if its nice again tomorrow ill change it and see what that does too..
    Tom Opgrand
    2011 Camry
      if your steering wheel moves easily its not the fluid..and probably not the belt..unless its just a little loose....not really sure.
        well your in luck its supposed to be like 45! haha
        • TsiTomT Offline
          TsiTomT Offline
          TsiTom
          haha awesome...this wouldnt be a big deal but there is sort of a metal on metal grinding sound too...not really loud but you can catch it
          Tom Opgrand
          2011 Camry
            isnt that kinda normal on a 1g?
              cross your fingers, squeeze your nuts, and pray the cups on your rack arnt shot....
                wow. nuts, cups, and rack all in the same post.. and it wasnt a drunk story.
                anyway. back on topic...
                  What year is your car? 7 bolt engine? Do you by chance have Crank Walk? I hope not , but thats the worst that could happin... lol
                  DSM'rs lets all pray for him!!
                  Kevin
                  sls
                    exactly what i thought when i first read this...hope its not crankwalk for him...1 week in his possession....dont worry im praying for him
                      listen to what he's saying here.... if you turn the wheel from lock to lock it goes away... if it was something crank/thurst bearing related, that would have no effect on the noise.... Tom is the belt loose, or does it feel tight? Just replace that, and get it tightened tomorrow, and see where that puts you.
                        it makes a grinding noise at idle and goes away when you turn the wheel?
                        • 9 Offline
                          9 Offline
                          92TSIpos
                          put some belt dressing on it once. that works for me.
                            i just say if its the ps, just get ride of it!
                            • TsiTomT Offline
                              TsiTomT Offline
                              TsiTom
                              Well here is what i did this weekend to it....first of all i checked the actual fluid and its supposed to be dexron III auto tranny fluid....the fluid was brown, sooo that i changed that out...and i tightened the belt but its still squealing...next plan of action is to just spray some wd40 on the crank pulley and pray for the best.....if that doesnt work then i might start thinking bearing but im not going to get ahead of myself just yet...
                              Tom Opgrand
                              2011 Camry
                                hello? alternator belt? without hearing it in person, of course
                                • TsiTomT Offline
                                  TsiTomT Offline
                                  TsiTom
                                  damn well could be too...i did tighten that one good...considering i had to loosen it to get at the ps.....but maybe it needs a change
                                  Tom Opgrand
                                  2011 Camry
                                    are you a member of www.dsmtuners.com yet? www.nabr.com ?
                                    • 94NDTA9 Offline
                                      94NDTA9 Offline
                                      You're power steering can make a squeel like noise when you turn it lock to lock if there is air in the system. It will almost sound like grinding/whinning noise. It will be full, and you can still turn it. You can turn the wheels lock to lock even with very low power steering fluid.
                                      I bet I would be able to tell if you let me hear it.
                                      • TsiTomT Offline
                                        TsiTomT Offline
                                        TsiTom
                                        not yet...if i dont get it figured out by the end of the week anyone that wants to hear it is totally free too...just when/where
                                        Tom Opgrand
                                        2011 Camry
