  4. computer wont dl with shareaza, kazaa, or winmx...?
21 Posts 12 Posters 782 Views
    or if you have cable or dsl.....type your IP adress into the internet explorer or wahtever you use....and go to configuration...then firewall.....and see what its set at.
      altho spybot search and destroy works it is actually spyware itself...and mwc...you mean if he has a router you type the routers IP address into the address bar and configure it on the routers web based GUI....
      • Turbo5OhT Offline
        Turbo5OhT Offline
        Turbo5Oh
        i would start off with checking to see if u have a 5volt reference coming from the flux capacitor if that doesnt work i would check the WWF port and see if the thingy-ma-bob has a cookie or possibly a brownie stuck in it, at the same time check to make sure your hard drive hasnt gone soft!
          LMAO @ Schell^^^^
            You forgot to tell him to make sure there are Dodge emblems everywhere inside there as well, cuz you know you can never have enough "RAM"
            • hondagirl17H Offline
              hondagirl17
              Limewire all the way baby!!
              ~ Laura
              All stock....for now!
              01 GSX-R600
              ~ :cool:
                limewire is shit...sorry
                  hondagirl17
                  I havent' had any problems with Limewire
                  ~ Laura
                  01 GSX-R600
                  ~ :cool:
                    whatever downloads your music go for it. i use ares cause limewire just crashed one day. it was good while it lasted and downloaded a lot faster then ares.
                    • JohnWJ Offline
                      JohnWJ Offline
                      JohnW
                      turn off windows xp firewall, install a 3rd party one (kerio for instance), forward all the proper ports. that should fix it. otherwise you will be operating in passive mode and will not be able to connect directly to another ip to download anything, which sucks. there are all sorts of faqs availible at the homepages of the various softwares that explain solutions to exactly these problems. do you have xp service pack 2? if so that could be the cause of your problems. it limits the number of ports you can have open at any one time. i was having some of the same problems, albeit with bittorrent, and getting rid of sp2 was the key.
                      90 Civic DX hatch
                      D16a6/y8 mini me
                        well i wouldnt say get rid of SP2...but you can definately configure your settings
                          just turn off the firewall. thats all you need to do. it doesnt do any good anyway. youd think that with the billions and billions of dollars microsoft has, they could make something that actually works.
