  3. Wanted Ads
  4. D16y8 Head
D16y8 Head
14 Posts 2 Posters 2.3k Views
    I plan on staying OBD0. Hey I'm all ears if you have a suggestion/advice though.
    As far as the Dizzy sure once I get this swap done.
    • L Offline
      L Offline
      legacy-user-131
      from what i read quickly you shouldn't need a new dizzy.
      http://crx.honda-perf.org/articles/z6swap/z6swap.html
      that article is for a z6 head, but basically the same;they don't mention a dizzy swap in there
      what do you plan to use for engaging vtec?
      also, from what i've read somewhere, i heard vtec doesn't respond well to boost.
      it may be worth checking that out before doing the mini-me
      94 Prelude SI
        Thats a lot of good information, for some reason some one told me that the z6 head would not bolt up to my a6 block.
        I was planing on using a tach with a shift light for engaging vtec, or a cheeper method.
        I have always been told vtec is just fine for boost, but its the compression that you have to watch out for.
        My compression is 9.1.1. and this will bring it down to 8.1.1. ( If I did my math right ) Perfect for boost.
        • L Offline
          L Offline
          legacy-user-131
          http://www.knology.net/~jediklc/D.htm compression calculator and loads of other info (i think your math is off also)
          the shift light idea will work and is probably around the cheapest.
          also, hondaswap.com has alot of info if you haven't found it yet
          94 Prelude SI
            Thanks for all your help Stock! I will read over every thing you presented me with.
            • L Offline
              L Offline
              legacy-user-131
              np; i've spent many hours trying to figure out how to get more power out of my d-series; i'm too cheap to buy a swap :).
              i'm also going to turbo my car, eventually :). first in line is the head gasket and MPFI swap.
              94 Prelude SI
                Hey we are in the same boat, cool. I would like to see your coupe this summer!
                By the way that head will raise my compression to "9.955900714787138" Unless I get the dual layer d16z6 head gasket. Heh heh my math was way off, Lol.
                • L Offline
                  L Offline
                  legacy-user-131
                  actually i sold the coupe back in oct. and picked up an 88 civic sedan for $50.
                  hope to put a junkyard turbo setup on it soon, i have pretty much everything except a dizzy, intake mani, BOV, and other little things.
                  94 Prelude SI
                    Ahh So are you planing making a log manifold out of a cx header? I'm going to be doing things like that to save money on my turbo upgrade.
                    $50 bucks is a damn good price for that car, 4 doors are cool looking. Wait is it burgundy colored and you got it off of 10th street fargo? If so its the car I planed on picking it up but some one nabbed it two or three days ago.
                    • L Offline
                      L Offline
                      legacy-user-131
                      nah, i'm in minot and i bought mine from a guy here; it is burgandy though
                      i'll be using the hf manifold and i'm not sure what turbo yet, i actually have 5 right now
                      there was a junkyard closing up here and me and a friend were allowed in and pulled turbos off everything we could.
                      94 Prelude SI
                        Really! So do you want to help a brother out and let go of one?
                        • L Offline
                          L Offline
                          legacy-user-131
                          i'll be selling at least 2 of them soon, i just need to research and see which ones i want for my car and a friend's car.
                          94 Prelude SI
