  4. Air Bag Suspension
Air Bag Suspension
11 Posts 6 Posters 807 Views
  • L Offline
    L Offline
    Lothurin
    more info would be nice...like type of car..how much he wants to spend ect ect.
    Lothurin
    Soul MotorSportz GM_FWD Jeff's Upholstery
    A+ Performance
      air bag suspension is REALLLY easy to install....i've seen it done without even a lift...and the guy was a idiot....so i'm sure the guy could do it himself if you really wanted to.
      • jct_4628J Offline
        jct_4628J Offline
        jct_4628
        its on a 90's style explorer....he wants to put 20's on and bag suspension, and then he's guessing he will have to customize the wheel wells to make it fit.
        Jason
        -06 WRX
        -95 CBR 600F3
        701-541-2568
        • dubbsyD Offline
          dubbsyD Offline
          depends how low he's planning on going. If he's planning on going down to the frame then yeah (which will probalby mean a lot of custom work elsewhere as well. betting it's not even possible with that front suspension setup), otherwise I doubt he'll be getting into the sheet metal with only 20s.
            he could bag it, and put 20's on with no work...but if he wants to go real low yeah he'll have to cut the fenders, fab the wheel wells and all sorts of shit.
            • dubbsyD Offline
              dubbsyD Offline
              ok so it's not going to be THAT easy (did some quick research)....
                it would be easy to just put the suspension on...but if he does want to DROP it to the frame...just tell him NO
                • D Offline
                  D Offline
                  dynotune
                  P I K Fabrication- custom air rides- they do fast air, hydraulics, and regualr rides- all custom St Cloud MN
                  Tell 'em I sent ya
                  andy
                  DynoTune Speed & Performance
                  Mobile chassis dyno service
                  www.dynotuneusa.com
                  (605) 753-1101
                    AntiBling
                    Is it a 4x4? I dont know if they even made 2wd exploders.
                    I think dakota customs in bismarck does a lot of air bags. That might be a place to look.
                    If he has the skills and would like to do it himself, first thing I would do is rip off the front suspension and find a mustang II or some superride type front suspension.
                    Then for the rear most likely would have to go with some type of 2 or 4 link. I would recommend a 4 link and he would most likely have to have the bags over the axle. But if he went the 2 link way look for a heavy duty 2 link and mounth the bags outboard of the frame rails onto the 2 link.
                    Up front Im sure hell have to remove the inner fenders and probably move some engine controls. He can either run without fenders wich isnt really good up here, or make some new inner fenders out of motorcycle fenders or trailer fenders.
                    In the back he'll have to notch the frame Im sure and cut up the inside to make a bridge cover and new wheel wells.
                    Just make sure whatever he does, he doesnt cheap out on the components he uses cause you will end up paying more to do it over then.
                    • jct_4628J Offline
                      jct_4628J Offline
                      jct_4628
                      thanks guys...I'll let him know
                      Jason
                      -06 WRX
                      -95 CBR 600F3
                      701-541-2568
