  4. Got a new toy today. :)
17 Posts 12 Posters 1.0k Views
    Bigger pics next time please. Oh and that's a pimp clutch to sit and look at huh! Too bad it's not going to actually make it into the car for who knows how long, 2 months? 3 months? Haha!!
      I was expecting some sort cheeseburger producing belt buckle....
      ...nice clutch tho
        hope you dont break anythin...
          exedy twin-plate? does that have some sort of special disc you have to use with it?
          what flywheel?
          • Sweet-WRX-LovinS Offline
            Sweet-WRX-Lovin
            ...nice clutch tho
            LMAO @ 92BlackTT
            One time...
              It uses exedy's discs for their twin plate clutch.
              It's just setup like a motorcycle clutch now. Friction and Pressure Plates sandwiched together in a clutch basket.
              • 2wheeler2 Offline
                2wheeler2 Offline
                2wheeler
                Really, cause my bike only has 1 pressure plate and sandwiches drive plates and driven plates(fibers and steels) together. Is it a wet clutch now like motorcycles or is it still dry like gay Ducatis?
                '08 Suzuki Hayabusa
                '09 Yamaha Zuma 200cc
                '95 E-350 7.5L
                  Sorry bout that. I didn't know the proper "names" for the different plates.
                  It does only have a single "pressure plate" on the outside.
                  Also the clutch remains dry.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    Looks expensive! Now when you going to get the release bearing set-up? 😉
                      The exedy doesn't use the release bearing setup that the Tilton does. So I will just be using a stock TOB.
                      I mainly went w/ the exedy after reading about replacement parts if anything does fail with it. Quite a bit cheaper for this one to break, if it does break, than a tilton.
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        Well then, that is good! Get it in your car. What else do you have left to get? Manifold done? etc.
                          It's close. Will make it's low boost and pump gas debut with the new setup on the opening weekend.
                          Should run the times it did last year on race gas on pump gas and 18 psi this yea rif it all works out.
