  4. radiator/water connection fix
8 Posts 4 Posters 493 Views
  • theobliviousT Offline
    theoblivious
    hey well apparently i blew a water connection or theres a leak in my radiator. Either way my car exploded with coolant so theres a leak somewhere. Anyways i cant drive my car to fargo without risking to big of a chance of overheating my car. Any suggestions of where i could get this fixed in moorhead? if anything on the weekend?
    BOOST....to be continued
    • XJHEADX Offline
      XJHEADX Offline
      How about your garage/driveway????
      • dubbsyD Offline
        dubbsyD Offline
        agreed. First thing you'll have to find out of course is where the leak is.
        • W Offline
          W Offline
          Wizard
          More than likely just a radiator hose. Either upper or lower. Then check the 2 coolant hoses going to the heater core in the dash. After that......radiator itself.
          A coolany pressure tester would be awsome at this point.
          Wiz
          1992 GVR4 598/1000 Nile Black
          1992 Tsi AWD
          1982 Datsun KC 4x4
          1990 Laser 2.0 AT NT
          1994 ES 2.0L NT 5-spd
          • XJHEADX Offline
            XJHEADX Offline
            Well what did you find out?????????
              theoblivious
              its my radiator. it has a leak on the top part of it. time for duct tape? for a tempory fix i mean
              • XJHEADX Offline
                XJHEADX Offline
                Uhmm yeah sure :eek: :eek: :eek:
                • W Offline
                  W Offline
                  Wizard
                  Seals All.......pick-up at your local parts store. Kinda like silicone but dries hard. Works great for the plastic end tanks of import radiators. As long as it's cracked on the main body. If it's leaking between the core and the endtank....new radiator.
                  Wiz
                  1992 Tsi AWD
                  1982 Datsun KC 4x4
