  4. Fox Body!
Fox Body!
17 Posts 7 Posters 1.1k Views
  • M Offline
    M Offline
    MrScary
    Pony_Racer wrote:
    www.mustangforums.com
    www.mustangworks.com
    www.muscle-mustangs.com
    congrats on the pick up as well 😄
    Except for the whole V6 thing. I'm wanting to swap a 5.0 as soon as I get some money. Anybody have any pointers?
    • 94NDTA9 Offline
      94NDTA9 Offline
      Unless the body/interior is in awesome condition, and you got the car for super cheap, just go buy a 5.0.
        About the 5.0, you need to have a talk with wildstallion, he will tell you everything u need to know about a mustang, no matter what year it is. When it comes to stangs, he's the king by far.
          i'd much rather have a 4.6 than a 5.0
          • 5 Offline
            5 Offline
            50stang
            There has already been a few good sites listed here for you to check out. I did the whole swap a 5.0 into a Fox a few years back as well... and one of the best resources I ever found was this site:
            http://www.jason.fletcher.net/
            Swapping a carbed 5.0 into a Fox can be a lot cheaper then swapping in a EFI 5.0 depending on where you find your parts.
            If you wouldn't mind having a carbed setup... my best recommendation would be to go find an old late 70's T-Bird for cheap with a 302 in it. You can use pretty much everything out of it... even the FMX transmissions that come with them.
            Just remember you need a rear or dual sump oil pan on a 302 for it to fit in a Fox Stang.
            If you have any other questions when you get going... feel free to drop me a PM.
            Good luck.
            • Pony_RacerP Offline
              Pony_RacerP Offline
              Pony_Racer
              Good luck.
              I agree carbed is simpler to work with and to manage most times imo.
              My old 85 mustang had a 4cyl in it originally then my uncle dropped a 351W then i bought her. Well much "cruisin" later she crapped out on me. So i got an old T-bird 302..(77 or 76 if i remeber correctly) and a C4 tranny and swapped that into her. I'd be glad to help ya find a 5.0 and swap it...but i'm not gonna be up there unitl end of may(ish). But its a fairly easy process with the right tools and help 😄
              R.I.P 1QK_PNY:icon_salut:
              • M Offline
                M Offline
                MrScary
                Well thanks for the imput guys. I was thinkin I would rather have a carbed. Also do yah guys know about the Cobra fox?
                  Pony_RacerP Offline
                  Pony_Racer
                  the Cobra R or just the base line 93 Cobra? i know alot about both of them.
                  • 0 Offline
                    0 Offline
                    03SVT
                    Did someone swap a V6 in your fox? I don't think I have heard of a V6 in an 86.
                    Anyhow, if you wante to buy a Gt, there are 2 here in Minot. If you want the swap, there are plenty of guys on the www.corral.net that have info on it. You wanna go carbed or fuel injected?
                    • XJHEADX Offline
                      XJHEADX Offline
                      more than enough info on the Corral
                      • 5 Offline
                        5 Offline
                        50stang
                        In 1986, Engine code "3" was a 3.8 liter, 232 cubic inch V6.
                        The other options that year:
                        Engine code "A" - 2.3 liter 4 cyl
                        Engine code "T" - 2.3 liter SVO
                        Engine code "M" - 5.0 liter
                        BTW, The engine code can be found as the 8th digit/letter in the vehicle's VIN.
                        • M Offline
                          M Offline
                          MrScary
                          Yep its a stock V6 TBI. What kinda prices should I look for when coming to the engine? And what was the year range for the thunderbird 302, I heard 70s?
                          • 5 Offline
                            5 Offline
                            50stang
                            It all depends on your mechanical experience and how much you feel you can do yourself... If you have to buy a fully rebuilt engine, it is going to cost more. If you can do some of the work yourself to the engine to get it back to tip-top shape, then you can find something cheaper. You can usually find an old 70's T-Bird with a running 302 for well under $1000. Like I said earlier, the nice thing is... you can use just about everything out of it. The Engine, Tranny, all pulley's, power steering pump, alternator, etc.
                            For our project, we actually picked up a '70 Ford F-100 with a 302 for $100 and used the engine out of that. The transmission (FMX) we took out of a '78 T-Bird though.
                            Pretty much any of those old 70's T-Bird's should work well for this swap project of yours. If you can, try and find one with a C4 transmission. The FMX we found works great, but I have heard/read the C4's were more durable.
                            Good luck!
                              Pony_RacerP Offline
                              Pony_Racer
                              Good luck!
                              And also 302's are one of if not the best engine as far as parts and mods, and the abundance of them anywhere. So even if the 302 is missing something like headers, heads......lots of options to find parts for em.
