  4. Anyone familiar with flaring and bending?
17 Posts 6 Posters 617 Views
    seanjohn
    I've upgraded all my under bay lines to stainless steel, however the line from the inlet hard line to the fuel filter is still soft, I would like to convert this to a SS line. I'm not planning on "T'ing' the line at all, simply upgrade the line.
      seanjohn
      I read the link, and I think I need to just see this done in person or something, because I'm a moron and am not following this at all. I need to read up on the basics and try to understand what is even trying to be achieved with a flaring tool etc.
        it might take some practice...
          seanjohn
          So what exactly does the flaring process do?
          • XJHEADX Offline
            XJHEADX Offline
            It spreads the end of the tube in the process it gets thinner. The back-up nut then tightens down on the fitting providing two things, a seal and a way so it cannot come off.
              it gets a tighter seal basically...
              • XJHEADX Offline
                XJHEADX Offline
                A standard flaring tool will create a 45* flare, which is most of the the old stuff and also most plumbing and LP gas line fittings. Inverted flare are high pressure systems, brake lines hydraulics.. AN- newer stuff.... AN came from Army-Navy
                  seanjohn
                  Ok, so you flare the line, place the proper fitting on the end (dependant upon the degree of the tool used) and itilize the nut to securt the fitting. Correct?
                  • XJHEADX Offline
                    XJHEADX Offline
                    put nut on first unless you have a plain end on other side.. If you are flaring SS get the clamps really really tight, it is hard to flare and can slip out of clamps,,, you'll see..
                      seanjohn
                      Ok, where can I purchase/rent one of these flaring tools? Is there anyone that would possibly be willing to let me steel theres or rent it?
