  4. the COLDest air intake
47 Posts 19 Posters 1.8k Views
    silly ricers...
      wow...thats stupid
      • harwood39H Offline
        harwood39H Offline
        harwood39
        wow, think about grabing that to work on it. COLD
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
          pin
          Why is that so stupid? It should work to bump the power a bit.
          Barry
          • assasainA Offline
            assasainA Offline
            assasain
            think about it, your craming even colder air through your engine than with a normal cold air intake which i believe makes hmm more power.
            • N Offline
              N Offline
              NightriderWRX
              Even though it seems like it'd work... the problem would be it'd become costly to resupply dry ice... plus wouldn't you think that the carbon gases (if dry ice is composed of it) would need to escape as well...
              <u>2004 WRB Subaru WRX STi </u>
              350awhp pump 93 octane
              430 awhp c116
              • Pony_RacerP Offline
                Pony_RacerP Offline
                Pony_Racer
                i want one lol 😄
                R.I.P 1QK_PNY:icon_salut:
                  why is it stupid.......... what are you gona do, run down the local 711 and pick up some dry ice to keep it cool? that's why it's stupid, it's imprtactical! in theory I'm sure it's good for another couple hp, but not worth it imo.
                    you could just buy nitrous and be better off...becuase im sure they charge a shit load for that
                    • uwatchnU Offline
                      uwatchnU Offline
                      uwatchn
                      Just use regular Ice ..... J/K.. lol
                      • assasainA Offline
                        assasainA Offline
                        assasain
                        im sure its impracticle but i mean you have to hand it to whoever made it, its a good idea.
                          The inventor of that product must be stopped. He and his kind will be the cause of 4 4ast 4 4urious
                          • assasainA Offline
                            assasainA Offline
                            assasain
                            sooo what part of that is rice now??????
                              putting a box full of dry ice around your cold air intake is going to add about as much hp as one of those winnebago shitter exhaust fans in your throttle body.
                              You need a cold air intake just about as bad as you need a wing designed for downforce at 190 miles per hour.
                              • assasainA Offline
                                assasainA Offline
                                assasain
                                it will add more than just a regular cold air intake...
                                  pin
                                  A colder air charge means the air is denser, which helps the combustion process to be more efficient. How is that useless?
                                  Barry
                                  • GarageAlchemistG Offline
                                    GarageAlchemist
                                    it wouldn't be worth 2 hp.
                                    97 GTi, 03 KJ
                                      pin wrote:
                                      ... process to be more efficient. How is that useless?
                                      this isnt very money efficient more than likely. this is just about as smart and my buddys idea to hook a duct from his a/c to his intake, so he would have a cold super charger. LMFAO, stupid wheeler.
                                        a/c into intake, thought about in the past then figured not worth time or the money
                                        • EfiniE Offline
                                          EfiniE Offline
                                          Efini
                                          You guys are looking at this all wrong, its not meant for you to keep it full of ice all the time, its meant for when ur at the track, to lower your intake temps. It's not all that dumb. I think most of you have been out at Sabin, haven’t you ever seen a domestic with a bag of ice sittin on the manifold? It’s an old drag racing technique used for many years, alot of professional drag racers do it. No it’s not gonna move you into the 12's but every little bit helps.
