Battery rules?
you can do-it-yourself for about a five dollar bill
The box doesn't have to be metal, it just has to be completly sealed and approved, which marine boxes are not. I used the Moroso box in my talon. Also unless your using a dry cell battery it must be vented to the atmosphere as well. The battery must also be fastened down instead the box.
Nick
SLS -
darkelvis wrote:
Yep, metal box. It must be properly BOLTED, not screwed into the trunk floor. Shut off switch doesn't shut off the battery, it kills the fuel system (i believe).WTF? Shut off the fuel system? This is getting more and more complicated. Why is it called a BATTERY shut off switch if it kills the fuel system?
Someone please explain this to me....I am completely lost. Just tell me everything i need to do to beable to run out at the track with my battery in the trunk.
So far i understand:
Sealed Box(bolted down, not screwed), Water cell batter must vent into the atmosphere, and the battery must be held down inside the box -
The cut off switch must shut everything off not just cut power to the battery. If you cut power only to the battery the vehicle will stay running for a period of time just off the alternator itself. Basically the cut off switch has to cut power to the alternator and the battery so that when the switch is turned the off position the vehicle will shut down.
In other words you're gonna need some relays hooked up to your ignition system so that it can be easily shut down, because honestly, most cars can run for a long long long time w/o their batteries. In fact the batteries ONLY purpose on a modern automobile is to provide a means to start the car (and during surges when the alternator can't keep up...but even then its not really efficient at that) and run your accessories when the key is switched off.
well did he gain anything by the wing?
since you will never ever have to turn the switch to off why dont you just mount it up and pretend it works.
Buy a mini battery and stick it into your glove compartment, problem solved!
