  4. Engine Design
Engine Design
28 Posts 15 Posters 1.6k Views
  • Afsil80A Offline
    Afsil80A Offline
    Afsil80
    Just copy the designs of the Toyota 2JZ GTE. I may be a Nissan guy, but I won't hesitate to admit that the 2JZ is arguably the best motor designed in the 90s.
    I don't know of any other engine that can make over 1000hp on a stock block.
    -Peter
    1991 240SX
      RB26+supra body=ultimate racer...
        4g63 makes massive hp, probably at least 1000, shep runs sub 9sec at 2650
        • Afsil80A Offline
          Afsil80A Offline
          Afsil80
          I normally dig Top Secret Japan, but that one just didn't do it for me.
          I guess I'm too much of a purist, hahahahahaha!
          -Peter
          1991 240SX
          • Afsil80A Offline
            Afsil80A Offline
            Afsil80
            Is 2650 supposed to be a hp number?
            And I know the 4G is a good motor, but 1000hp isn't as reliable on that motor like it would be on others Granted, I've seen stock block Evos belt out over 500, but anything over 550 is pushing it.
            I think the best way to say it, is that a stock cast iron block will take a LOOOOT more power, boost and abuse than a stock aluminum block ever will.
            -Peter
            1991 240SX
              4G63's are iron blocks...and the blocks can take a shitload...
                sorry, 2650lb is shep's race weight.
                why can't some good sleeving solve the problem? hasn't a b-series block been pushed to 700+hp? good aluminum block with some hefty sleeves and perhaps some reinforcing should have no problem with the kind of abuse that cast iron takes
                • M Offline
                  M Offline
                  MrScary
                  Wow theres a ton of options. I might just stick with a pretty simple inline 4. Maybe 4 valve dohc. The rotary would be awesome but I don't think I have the time or smarts to design it. Where could I find some blueprints or somethin so I could get some design help?
                    rx7forums.com
                      www.nopistons.com
