safc-2 intall into EF civic questions
alright so im trying to install my safc-2 into my EF.... i had this in my EG but i didnt have the pinouts like i had with that...i printed a chart off of "effin works.com" that they put out for the MPFI swap... so i have most of it figured out.... but someone please help me figure the rest out.... and tell me if im right with the stuff i think i got figured out....
ok so i have the brown/black ground wires figured out because there are about 10 different ground pins on the ecu
green wire- is the RPM wire... but i cant find what it would be on the chart
gray wire- TPS wire... well, there are a couple different ones it could hook up to, so which one would it be? on the chart it says it could be
**c7 **(throttle (position) angle sensor)
c12 (PA sensor/ignition timing adjusting connector/TA sensor/TPS sensor/TW sensor)
C13 (PA sensor/(TPS sensor)
so im guessing its probably the C7 pin? because it has nothing else attached to it or whatever -
red wire- power supply... i havnt found a pin on here for that power supply... could i just hook it up to like one of the injector wires for power??? or where is a good one to splice into
and i dont have a knocking sensor so i dont have to hook up the purple wire.
what the hell kind of sensor do i have for the pressure sensor.... im guessing its the karman? and what wires on the SAFC hook up to which on the ECU... again there is three pins it could go to...
C14-green/white
C15-yellow/red
C11-white 1
which one do i splice my two wires into? the white one?
if you can offer any info that would be great... or if you could point me in any informative links it would be well appreciated..... thanks for looking atleast
also.. anyone have any basemaps? im using dsm 450's... i know i can set then at
-40% but anyone have anything better? -
