  4. I have a prob. with my car n i dont know wut it is
15 Posts 10 Posters 682 Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    im goin to say head gasket
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      Sell it.......
      • 94NDTA9 Offline
        94NDTA9 Offline
        I'm gonna say it's your alternator.
        • civtegraC Offline
          civtegraC Offline
          civtegra
          lol alternetor????? 😄 its black smoke 😕
          • 94NDTA9 Offline
            94NDTA9 Offline
            Oh BLACK smoke....def the battery then.
            I'm sorry, I'm not helping.
            Oil is seeping into the antifreeze, and probably vice versa. Headgasket.
              the general description of a bad headgasket are: loss of coolant and oil, discoloration of exhaust, loss of power
              based on what you've told us... i think the general concensus is that you need a new headgasket. while you've got the head off... get work done by www.gude.com or find a reputable company over honda-tech
              • ticklemedalyT Offline
                ticklemedaly
                or if you are local, just have quality engine work on it for you. pull it yourself, let them re ring it and get new bearings done, complete the whole machining process and you will have a great running engine. remove all unnecessary things that will cost more and will charge more.
                XBL G-tag: TickleMeDaly83
                • civtegraC Offline
                  civtegraC Offline
                  civtegra
                  How much u sugest itll cost ?????
                  • bluejaysB Offline
                    bluejaysB Offline
                    bluejays
                    are you doing it yourself or taking it in?
                      no reason to do all of that if it's a head gasket... head gaskets are like 100 bucks.... if you can do the work yourself. If not I'm sure it'll be a good 500 bucks. Quite a bit of labor
                        i don't know.... he does come across as being pretty slow, and he has an expensive swap, (unless he's really slow) they'll probably try to soak him for 200 or more over the cost
                        aren't headgaskets usually close to 1k though?
                          Headgasket in an integra runs about $500 w/ parts, including new water pump and timing belt.
