  4. Brake Problem
Brake Problem
20 Posts 10 Posters 1.6k Views
    One Word... HACKSAW!
    • ticklemedalyT Offline
      ticklemedaly
      ic what you are saying, go to sears and get the craftsmans bolt out kit for like $20-30 and get it out that way, or try and use a vise on it. Any parts store should have a caliper slide kit for your car.
      XBL G-tag: TickleMeDaly83
      • StangerBanger96S Offline
        StangerBanger96
        and just leave the rest of the bolt inside the caliper
        good one joel :rolleyes:
          just replace all of your brake system and get high performance stuff
            StangerBanger96
            well after about 45 min of pulling, torquing, spraying with lube and rust destroyer and every other thing we could think of, it finally came out.
            Not only was it rusted into place, but it had .......whatever that bonding agent for threaded things is, so it was double stuck. We got it out though and replaced it so hopefully any future work is 400x easier now.
              ticklemedaly
              that was lock-tite, so it doesn't vibrate loose. Main reason for fasteners get stripped is because of improper usage of tools, (wrong socket/wrench size, bad angle, over torquing, etc, etc) lock-tite works perfectly fine as long as the fastener isn't damaged either when it is installed or loosened. Not saying it is your fault, could have been something in the past.
              • 9 Offline
                9 Offline
                92TSIpos
                I would have used a little heat on it. Just an old farmers trick. Seems to work everytime. 🆒
                • D Offline
                  D Offline
                  dynotune
                  Doesn't that bolt have a torx head on it??? I believe most of them do, and by looking at the picture it seems that way also.
                  DynoTune Speed & Performance
                  Mobile chassis dyno service
                  www.dynotuneusa.com
                  (605) 753-1101
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    Hahahah, that is funny stuff. I am assuming that whoever it was that posted the original question thought it was supposed to be a hex head bolt?
                      what are you talking about? heat makes things expand.
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        Obviously you don't know what you are talking about. You heat the nut, or area around the bolt, which makes that expand, and waalllaaa your have a freed up bolt(hopefully).
                          pin
                          Lol
                          Yeah, the picture is blurry, but it does look like a Torx bolt. I've got a set of Torx sockets if you need me to help out.
                          Barry
                            StangerBanger96
                            we got it out no need for help now....it didnt matter what the original bit was thats what i meant though. It was a literal circle on the outside and circle on the inside from all the rust/wear on it. Id assume it was the people/mechanics who worked on it before we bought it because it was a salvage titled car so they probably took lots of it apart and back together, who knows. Its off and replaced now though.
                              how does one prevent the heat from transferring to all of the parts?
                                oxyacetalean torch(sp?) it heats the part so fast it doesnt have the chance to spread so its concetrated...
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  experience helps dont it felas?
                                    ticklemedaly
                                    experience helps a lot, listen to others who are wise, and dont be afraid to ask questions, just dont act like you know what you are doing when you dont know jack shit.
