  4. acceleration of gravity
14 Posts 8 Posters 493 Views
    very well said. ^
    personally, i dont see how figuring out how he fell is disrespecful. the discussion wasnt conducted in an immature manner. (like "hahahaha. he fell off the bridge at 22.4mph! sucks for him!! baaahahahah.") so why all the fuss? like adam said, if we were shaken at every traumatic event in life, we wouldnt be able to go on. applying science to a tragic event only helps us better learn about it.
    i can say for an absolute certainty there was no intentional disrespect in the original discussion.
      I saw footage of my friend getting shot yesterday with a shotgun. That was actually hilarious. 🙂
      I'll post it later. 😉
      • harwood39H Offline
        harwood39H Offline
        harwood39
        i wish i had footage of my friend getting hit in face with the golf ball, cause he fell backwards like a board and was unconsious for a while.
        I didnt mean to come off like an ass, cause personally i laugh about everything that happens to me. But i konw some people dont like to be talked about like that.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
        • 91nbtsi9 Offline
          91nbtsi9 Offline
          out there wrote:
          because the thread apparently got deleted (why?) before i was able to look at it today, i'm going to start a new one
          nate's reply
          The resistance from air or anything else would be negligible at this slow of speed. >His terminal velocity, from a 50ft fall, would be 38.7mph as adog said. I don't know >about you, but I wouldn't want to run into something that is stopped at 38.7mph >with only a helmet protecting me.
          out there, what the heck is 5m/s/s? I think you meant, 5 m/s^2?
          the acceleration of gravity is 9.8 meters per second per second (m/s/s is a common abbreviation); however, the air resistance of a body and the clothing on said body would likely cause it to fall at a slower rate. i'm just guessing at how much slower it would fall, but based on the numbers chuck posted about terminal velocity (spread eagle vs headfirst), i think i was being kind of generous in only reducing the rate by about 50%
          at 5m/s/s, a body would fall 16.4ft in the first second and accelerate to 11.2mph, then fall an additional 32.8ft in the next second, accelerating to 22.4mph, and that's roughly the distance from start to stop.
          because the air resistance is so small at a speed this low, i assumed constant acceleration, which is probably as silly as this thread 🙂
          No, the acceleration of gravity is 9.8 m/s^2, have you ever had a physics class? Do you understand what acceleration is? Your abbreviation is retarded, m/s/s would simply equal to m, the seconds would cancel each other. You can't just modify the force of gravity. Gravity will be applying a force of acceleration to an object at 9.8m/s^2 no matter what (or about 32.2ft/s^2). You can't just say, oh, this object will have this much air resistance, lets just lower the force of gravity to estimate it. The air resistance would be pretty small going from a stop to ~40 mph, you can ignore it.
          Adam (I think that is who it was) and I were correct, it would be about 38.7mph from a 50ft fall. Granted, there would be a small amount of air resistance once the object got some speed, but with the speeds we are dealing with, it is negligible. If we all really care that much, I can calculate the actual resistance from the air, and give us a real close answer. I am pretty lazy right now though.
          Maybe you should stick to delivering pizza?
            I deleted the other thread for other reasons than the gravity part. Anyways keep being intellectual.
              the other thing to keep in mind is that you don't instantly reach terminal velocity, so you are in fact going slower than 9.8 m/s^2 if you "only" fall 50 feet. I forget how far you need to fall before you reach terminal velocity, but I believe it is over 100 feet...I could be wrong.
                i know what the acceleration of gravity is
                http://www.glenbrook.k12.il.us/gbssci/phys/Class/1DKin/U1L5b.html
                http://www.homepage.montana.edu/~uessc/esci450/RamCalculations.html
                http://www.physicsclassroom.com/Class/1DKin/U1L5a.html
                i wasn't sure how to abbreviate the acceleration of gravity, so i looked it up, hence the reason i said that "m/s/s is a common way to abbreviate it"
                i was guessing that with the size of a body and the clothing on it, it's acceleration would be reduced. i understand that gravity is a constant, but i also understand that acceleration isn't.
                i know that you have much more understanding about this stuff than i do, but at the same time, you are too concrete with theoretical numbers. after watching some footage of things of various sizes falling short distances, i was way too far off with reducing acceleration to 5.
                  O.K. enough nerd talk already.
                  Sorry, I had to say something. You could cut the tension with a knife.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    Acceleration on a free falling body is constant. Velocity and the force from air resistance are dependant on acceleration,time, etc.. Why am I too concrete? The force of gravity is concrete..:)
                    huh? 9.8m/s^2 is the force or acceleration on a free falling object, it is not a rate or speed. I think you might be confusing a few things. The 9.8m/s^2 force is present at all times, whether the object is in motion, or just sitting there. Even on all your lazy asses that are reading this have a 9.8m/s^2 acceleration force pushing down on you right now, hence why your ass is getting sore. You are right, the "body" or person in this case, is not going to reach terminal velocity in 50ft, the the acceleration on that body is the same the whole way down. What terminal velocity is, is when the resistance force from air and any other resistance the object encounters while falling is EQUAL to the force of gravity on the object.
                    • 91nbtsi9 Offline
                      91nbtsi9 Offline
                      Sorry Wes, class is over now, next week we continue on centripetal force! 😛
                      jk
