  4. a/f gauge worth it?
a/f gauge worth it?
15 Posts 10 Posters 804 Views
    pin
    You can't use them for tuning. They don't do much at wide open throttle, since the gauge reads a narrow voltage range coming from your stock oxygen sensor. I've had a very nice a/f ratio gauge in the past(Split Second ARM-1) and the best thing it did for me was indicate that my oxygen sensor needed to be replaced. There are other ways to figure that out, so it wasn't worth keeping.
    Barry
    • uwatchnU Offline
      uwatchnU Offline
      uwatchn
      You can go ahead and get a wideband O2 heres a company in austrailia i heard about and they sell from what I heard pretty good set ups
      http://www.techedge.com.au/vehicle/wbo2/default.htm
        awd95mn
        has anyone heard about the zeitronix logger with wideband, boost and egt readings?
          If you want the gauge look with a wideband O2, get the UEGO. Its the only gauge (that I know of) that actually means anything when its hooked up.
          • darkelvisD Offline
            darkelvisD Offline
            darkelvis
            don't waste your money on zeitronix.
              It's like a dance party in your a pillar!
              • RaiderR Offline
                RaiderR Offline
                Raider
                I have my a/f gauge wired into my downstream O2 sensor...this gives me a constant reading unlike what the front O2 does...the constant swithing is for show..the rear O2 gives me a good readout..I have compared it to the wideband
                POWERD BY
                  autometer is unvieling a wideband 02 sensor at sema this year.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    http://www.innovatemotorsports.com/products/xd1.php
                    Here you go. I had/have the innovate wideband, works awesome, others on this board use it as well. This will probably be cheaper than the AEM UEGO? Not sure. Worth a look!
                      darkelvisD Offline
                      darkelvis
                      I use the Innovate, and i wouldn't use anything else.
                        I think he was looking for a gauge he could put in a pillar. Otherwise yes, the innovative wideband is very good. I personally use this legacy image
                        as it datalogs with my ECU. I think the UEGO can be set up to datalog into the AEM unit as well...dunno for sure though.
                        • 91nbtsi9 Offline
                          91nbtsi9 Offline
                          Look at the link I posted Mr. I am quick to reply. Innovate has a gauge now that can be used with the LM1 or by itself. Oh, and the AEM can be setup to datalog any wideband, AEM rules:)
                            oh...heh, my bad. Just saw innovative and well...you know.
