  4. New Addition to the STI
35 Posts 12 Posters 2.2k Views
  • legacy-user-33L Offline
    legacy-user-33
    That only took about ...what 2 months......slackers
    -Tin-
    -IS300-Black on Gold-
      Exhaust first, then boost controller, fuel mods....
      • J Offline
        J Offline
        JDMSTi
        boost controller?...yeah ok then i ask when do u plan an engine rebuild?
        get engine management not some boost controller...and if you just want some more boost and not alot just get a ECU reflash program
        Nice STi btw!
          this thing purrs. fucking pimp shit.ty tint mast i mean SLS.
            doesnt he already have 3'' exhaust? i spose a downpipe would atleast be logical
              Nice STi btw!
              do they blow up easy or what?
              • NickBN Offline
                NickBN Offline
                NickB
                i don't think its 3 inch
                  2.75 i think.
                  • NickBN Offline
                    NickBN Offline
                    NickB
                    i think its 2.5
                      The problem w/ the WRX (and I assume STi as well) is that the factory ECU always tries to get it to wrong at stock performance, no more and no less. Sometimes it will cut/add fuel, others it will advance/retard timing. BY FAR the best thing you can do to squeeze more power out of a Subie is with an ECU reflash or Piggy-back/stand-alone ECU. ECUtec is probably the most popular reflash, TurboXS UTEC is probably the most popular Piggy-back and Elementtuning IMHO has the best overall package (I THINK its a piggy-back as well, but it may be stand alone).
                        legacy-user-33
                        STI comes with factory a downpipe....1 3/4" i think
                        -Tin-
                          I'd hope the stock downpipe is bigger than 1 3/4" on the STi, I believe the stock WRX one is 2"+ (I'd go measure but I'm lazy). What I think they meant was a cat-less downpipe around 3 to 3 1/2". Actually, every turbo car comes w/ a downpipe, otherwise the exhaust would just exit directly from the turbo.....
                            i dont think they would put anything bigger than 2inch on a stock wrx or STI
                            • F Offline
                              F Offline
                              Fitzy
                              I have had a boost controller on my STI since I basically got the car and have have absolutely no problems, although you do not want to go over 16 psi otherwise you will just detonate and the ECU will pull timing anyways.
                              The DP on the STI is the same DP on the WRX. STI does have larger stock exhaust on it and the other major difference in exhaust is the STI uppipe is catless. If you want to do a turboback on the STI you WILL NEED to port the wastegate otherwise you will get boost creep.
                              Element tuning ECU is a full standalone along with the capability of removing the MAF and going to speed density. SWEET!
                              2002 Honda S2000
                              2006 Dodge Ram CTD
                                Mine was 2.25" stock
                                • YellowEvoY Offline
                                  YellowEvoY Offline
                                  YellowEvo
                                  still slow though right Kirky???
                                  2003 Mitsubishi Evolution 8
                                  2011 Ford F150 Ecoboost
                                    i hope no one thought that i was saying that he didnt have a downpipe...tjamz said somethin about that
                                    • J Offline
                                      J Offline
                                      JDMSTi
                                      Im not saying your going to blow your engine...its just most ppl wanna turn up the boost and they think hey i'll just spend 200bucks on a boost controller to crank up the performance instead of $500-1200 for an ECU program or Piggyback system.
                                      They are safe if you arent an idiot ricer about it but for the most part i'd spend the $ on an ECU program or some engine management that changes all of the perimmiters and not just boost.
                                      Almost everymod will have an effect on what your ECU is doing...most intakes lean out your mixture and most ppl wouldnt do anything about it even if they already have a car that runs lean. I just think cheap mods like boost controllers and Super AFC's are junk and are a cop out to "real tuning" Just my $.02
                                      • J Offline
                                        J Offline
                                        JDMSTi
                                        btw my car came with 2.25 inch piping throughout the exhaust im pretty sure an STi would be 2.5 or 2.75
                                          Nice STi btw!
                                          I'm confused? First it sounds like the STi will blow up with a boost controller, but next, it wont blow up if you aren't stupid about it. I guess what I mean is, Kirk wouldn't go fiddling around with his boost controller, cranking it up to 30psi... And he has the people to help him not run lean / blow things up. Honestly though, $200 for a boost controller?
                                          Also, I dont really understand why S-AFC's are junk... care to elaborate? I guess all of us with just boost controllers and afc's don't really "tune" our cars? Hmm... I guess we should just ignore Nick's conservative "piggy back" afc tune for 530whp...
