Turbo or Engine?
OK in the last month and a half my car has been blowing out blue smoke while idling it doesn't get worse as I accelerate or anything but while idling it billows out.
I inspected the ic pipes recently while custom fitting them to my car. The pipes were relatively clean on the inside which leads me to suspect that something is causing the engine to eat oil.
Maybe I am wrong? (Probably) Could it be possible that the turbo is eating oil instead of the engine? The turbo is not that old maybe 3500 miles on it. If it is the turbo then that will be enough motivation for me to get a 50 trim or larger.
What really sucks is that my Talon is my DD until I get the Grand Slam up and running decently then the Talon will hibernate with a few wake-ups for some parking lot fun.
compression test compression test compression test
Yeah I have been meaning to do one since I got the car. -
What kind of turbo are you running? Sorry dont know yoour car.
krzydrftr93 wrote:
What kind of turbo are you running? Sorry dont know yoour car.Just a lil ole' 16g. -
Ya i was going to go with a 16g for my dd 91 fwd DSM and fmic and all 3 inch pipe and shit
That is basically what I have right now. As far as the compression test, yeah I am scared to see what the results are. -
hrm.....
Car smokes when idling......and I'm guessing at first start up too right?
That's valve stem seals. Very common.
If you get nasty blue puffs of smoke during shifts (off-throttle), suspect turbo. But, usually a failing turbo isn't just at idle.
Screw the compression test, if it runs without a miss it's going to pull 145 or better across all 4. I say, drop downpipe and check for oil. If little or no oil is found in o2 housing.....my bet is valve stem seals.
Wiz
