  3. Wanted Ads
  4. Greddy type S BOV
Greddy type S BOV
6 Posts 5 Posters 841 Views
  • Big-DB Offline
    Big-DB Offline
    Big-D
    Im looking for a Greddy type S BOV because the discontinued them.
      since they are so rare...ill let mine go for $8000...but thats only if you come pick it up...why dont you buy a type RS?
      • TsiTomT Offline
        TsiTomT Offline
        TsiTom
        i dont know i was told they suck...
        Big-D on toms account
        Tom Opgrand
        2011 Camry
          I will let mine go for $7995.
            Who told you they suck? Are they retarded?
            I'm sure Greddy would make a shitty product.... oh and the one on mine and Brians care are TERRIBLE (sarcasm).
            It has a wider diameter valve, its quicker responding, its louder (for you ricers), has interchangeable recirculation noses... lots of stuff... and its polished 🙂
            Created to be the most reliable blow off valve system available, the Type-RS's state-of-the-art design allows for greater performance in a compact size. Improved response and increased pressure are achieved through carefully selected spring rates and a large 40mm valve. The real unique feature of the Type-RS blow off valve is the CNC machined 8 discharge ports that draw in the surrounding air to amplify the blow-off sound. The Type-RS is compatible with the standard GReddy Blow-off Valve flanges.
            Features:
            High capacity performance, and a compact frame
            8 discharge ports that draw in surrounding air and release a unique sound
            40mm, hard-anodized valve for increased airflow
            High-quality diaphragm and short stroke significantly increase response
            Dual spring system promoted response and allows for high boost pressures
            Optional discharge adapters for rerouting discharged air
            • Big-DB Offline
              Big-DB Offline
              Big-D
              i just heard that the type S was better i havent done any research on them so i guess i shouldnt have said they sucked i just heard they did.
