  3. Wanted Ads
  4. WTB 89-92 Grand Prix/3.1 etc. ND,SD,MN
18 Posts 5 Posters 684 Views
    musthavemuzk wrote:
    is this to be a daily driver or what is the plan?
    not a whole lot of support for the engine if you are thinking to make it quick.
    i sold my maroon 93 4dr GP early this summer. 3.1 3spd auto. kept the 90 cutlass supreme as i liked it much better.
    Monty
    I got a 90 turbo prix engine and trans. So im looking for a car for it. Your right about the NA 3.1. The cutlass thats my second fav out of the w-bodys.
      94s started with the 3100s but it should still bolt right in...the only thing your gonna have to do is change the wiring i believe...and then if you get that 94 car you can take all the top end pieces off of the 3100 and have the hybrid turbo motor...
        Did some checking on w-body last night. 1993 was the last year your right! I like your idea about the hybrid turbo motor. 🆒 Has anyone tried that??
          yup and it has produced some good numbers as well...the 3100 flows a lot better than the 3.1 mpfi...the heads help even more but then you have problems with the exhaust manifolds but the intake manifolds+tb bolt right up...and actually i have a 3100 top end sitting in my room right now that has been ported and polished...both upper and lower intake manifold and throttle body that id be willing to sell
          • PhatsP Offline
            PhatsP Offline
            Phats
            Tony help a brother's funding out here, gotta 91 beretta, 3.1, can this guy use ut at all??
            02 GSXR-1000
            97 540i
              i believe everthing can be used...if nothing else he can take his turbo parts and bolt it right on there and have a turbo beretta which will be faster due to weight...there are like 1 or 2 running around the country and thats about it...
                Give me a pm with a price. Is there a write up on this? or is it a pretty simple job?
                  i believe it is a straight bolt on job...post on w-body and ask them...those guys have done it already...
                  • M Offline
                    M Offline
                    musthavemuzk
                    might also find some help at 60degreev6.com (if the site is still up).
                    that is all about that 60 degree V6. 2.8,3.1,DOHC3.4, 3100, 3400.
                    beretta.net is one of the beretta scene. bstuff.com i think is another.
                    Monty
                    14.59 at 94.85 still stock
                    www.pbase.com/musthavemuzk
                    • D Offline
                      D Offline
                      DerekN
                      I would go to bstuff.com more info and quicker responses just don't come on like a noob(you'll be flamed), there is a search on there that will give you a lot of topics on turboing a retta! Like said before not too many turbo'd rettas most people just swap in a 3400 instead with a 5spd! Good Luck!
